20 Most Recent Maytag Atlantis MAV7000 Questions & Answers
Hi I have a maytag
Carbon brushes have to be replaced
11/22/2017 6:45:29 AM • Maytag Atlantis... • Answered on Nov 22, 2017
Washer will not fill on cold water at the start of
This sounds like a hot AND cold fill washer? If so ->
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
10/23/2011 1:10:00 PM • Maytag Atlantis... • Answered on Oct 23, 2011
I am currently having a
I WOULD SAAY YOUR HEATER ELEMENT IS FAULTY
10/16/2011 7:11:06 PM • Maytag Atlantis... • Answered on Oct 16, 2011
MAYTAG MAV7000AWW PULL OUT SWITCH IN COLOR OR
If you are blowing fuses or tripping the breaker in the color and delicate cycle but not the whites, you have a short in the timer. Here is a link to the replacement part you will need.
2/11/2011 9:31:03 PM • Maytag Atlantis... • Answered on Feb 11, 2011
Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
4/24/2010 9:40:05 PM • Maytag Atlantis... • Answered on Apr 24, 2010
When washer is emptying it squeals sometimes, not
sounds like the pump and belt need replacement / pls leave feedback mm
12/7/2009 10:35:38 AM • Maytag Atlantis... • Answered on Dec 07, 2009
Will not Agitate but will spin fine
Make sure washer is unplugged before beginning repair.
Remove the agitator from inside the washer by loosening rubber nubs with a screwdriver.
Then loosen bolt underneath agitator cap with a socket wrench.
Check clutch assembly area for wear and tear. They can be found in the upper portion of the agitator assembly.
If the dogs (which turn the clutch) are in bad shape, try replacing with a dog kit.
Put agitator back on and test
If its spins out on the next load you do, you're good to go. It could be one these more complex issues: Bad Wiring harness, Bad Motor, Bad Transmission, Bad Motor Coupling.
Thank You for using Fixya.com
8/13/2009 11:56:03 PM • Maytag Atlantis... • Answered on Aug 13, 2009
MAV6200AWW; fill correctly then nothing, does not cycle at all
if the motor is not getting power are you sure you properly checked your lid switch? when you close the lid slowly do you hear a click sound?
6/27/2009 2:48:54 AM • Maytag Atlantis... • Answered on Jun 27, 2009
Is it the motor?
The usual "screeching noise" in these washers is most often from the pump. Tilt the machine up so you can get the belt off (no tools required) and then turn all three of the pulleys. The center pulley is the transmission, the movable one is the motor and the last one is the pump. You will probably be able to feel or hear the noise and take appropriate actions. Good luck. AJ
5/22/2009 8:04:32 PM • Maytag Atlantis... • Answered on May 22, 2009
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
5/18/2009 2:50:22 AM • Maytag Atlantis... • Answered on May 18, 2009
MAV7000 clicking sounds in all cycles. sounds like
Sounds like there is an obstruction striking or rubbing against the impeller in the drain pump assy. It will require removing the front cover/ Drive belt from the bottom of unit/ Hoses from drain pump (be prepared for the water) a 3/8" socket to remove the pump & a needlenose plier to remove the obstruction... Hope this helps....Bill
5/18/2009 2:47:45 AM • Maytag Atlantis... • Answered on May 18, 2009
I have a Maytag Atlantis MAV7200 and there seems
http://www.pcappliancerepair.com/model-display.php I don't see any filters at this site for your machine. You could take the pump apart to check it for obstructions. See if you can push the inner drum aside so you can check for anything in the bottom of the outer drum that is not getting pumped out.
5/13/2009 9:58:30 PM • Maytag Atlantis... • Answered on May 13, 2009
Won't spin or aggetate
http://www.pcappliancerepair.com/model-display.php Check the motor pivot spring, too. It holds the belt tight. Check this site for parts and help.
5/13/2009 9:47:05 PM • Maytag Atlantis... • Answered on May 13, 2009
Maytag washer mav7000: clothes wont spin dry
http://www.pcappliancerepair.com/model-display.php From what I see, your machine has a drive belt. Check it for damage or see if it has anything on it making it slip. Check the pulleys to make sure they are not worn out.
5/13/2009 9:38:04 PM • Maytag Atlantis... • Answered on May 13, 2009
Whirlpool Topload Washing machine Model 6ALSQ8000
It sounds like you need a door switch you must remove the cabnet off the unit.You can get the part by contacting whirlpoolparts.com for parts near you hope i helped :)
5/11/2009 7:57:09 PM • Maytag Atlantis... • Answered on May 11, 2009
Maytag MAV 7000 stopped in rinse cycle with water
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
5/5/2009 5:20:44 PM • Maytag Atlantis... • Answered on May 05, 2009
Spin cycle starts, but tub stops spinning after a ~ 20 seconds
check the spin clutch
4/28/2009 5:20:48 PM • Maytag Atlantis... • Answered on Apr 28, 2009
Washing Machines Logo
29 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
washer will not fill cold water start
  • Washing Machines
