20 Most Recent Cuisinart BFP-703 Blender Questions & Answers
I have a Cuisinart BFP-703. It started smoking while chopping ice. It stopped working. Took bottom off, unscrewed board, tried following wiring, one white and one black from board.
Sometimes they can be soldered to a circuit board. If it is inline, it could look like a small metal tube with what looks like white porcelain on one end where the wire comes out. If this is present, it is a circuit breaker similar to a fuse but instead of blowing with an electrical overload, it is sensitive to heat like from an over heating motor. This may be glued to a solid part of the motor like the steel plate lamination and must be replaced. These don't reset. These can also be completely inside a piece of plastic tubing as their leads are not insulated. Good luck.
1/3/2019 4:44:48 AM • Cuisinart... • Answered on Jan 03, 2019
0answers
The plastic gear / splines on the SSB1U Cuisinart
then I will need to findout what bits go where
11/7/2013 6:32:20 PM • Cuisinart... • Answered on Nov 07, 2013
My blender seems to have locked up, I would like to replace it, how do I do that?
It depends on whether or not you have a manufacturer's warranty on it and if it's still under that warranty.If so, there should be contact information on the warranty card it usually comes with and steps on how to arrange for a replacement.Otherwise, you may have to go into the place of purchase and buy a new one, unless you know someone that can repair blenders having issues like this.
5/5/2012 7:54:38 PM • Cuisinart... • Answered on May 05, 2012
My cord to my bfp-703 cuisinart blender melted can it be replaced ?
Unfortunately it cannot. Cuisinart does not sell parts direct to consumers. However, their products carry 3 year warranties. Contact Cuisinart directly and they will be able to assist you with getting the unit fixed.
4/9/2012 3:47:24 PM • Cuisinart... • Answered on Apr 09, 2012
The bottom gear on my
Hello, maridI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
10/28/2011 10:26:06 PM • Cuisinart... • Answered on Oct 28, 2011
0answers
The rotor on the base for the food processor will
Usuallt, it is simple - you have the position the gear box of the food processor side until there is no gap between the gear box and the teeth on the base - this usually takes me a few tries to get it right.
If you are confident that there is no gap, call Cuisinart and see about getting a new gear box - 1-800-726-0190
9/29/2009 7:28:32 AM • Cuisinart... • Answered on Sep 29, 2009
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
12/12/2008 7:15:05 AM • Cuisinart... • Answered on Dec 12, 2008
2answers
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
10/19/2008 9:33:20 PM • Cuisinart... • Answered on Oct 19, 2008
Cuisinart blender. How to fix a noisy one please?
Are you blending ice cubes? They are NOISY. Blenders are generally noisy!
1/26/2023 6:57:23 PM • Cuisinart... • Answered on Jan 26, 2023
My cuisinart soup maker is leaking through the blade
clean and tighten blade --if still leaks replace seal or need replacement base if damaged
1/26/2023 5:39:41 PM • Cuisinart... • Answered on Jan 26, 2023
How to replace the plastic locking piece on a Cuisinart?
Edited to correct spelling of 'Cuisinart'. Moved Category from Cars and Trucks to Cuisinart Blender. Cuisinart make blenders, BBQs, toasters, stand mixers, air fryers, fridges, and many more, but you give us no clue what your mystery kitchen appliance is! The search query is make model parts schematic Cuisinart also have their own parts page https://www.cuisinart.ca/parts?lang=en Places like this https://www.ereplacementparts.com/cuisinart-dlc10s-pro-classic-food-processor-parts-c-147322_147329_147423.html are reached from here https://www.google.com/search?q=cuisinart+food+processor+dlc-10+parts+schematic If you need further help, click COMMENT. ..
9/2/2021 11:40:42 AM • Cuisinart... • Answered on Sep 02, 2021
Model BFP-703. Why can't locking ring be removed?
Some lubricant might make removal easy.
7/24/2021 4:20:45 AM • Cuisinart... • Answered on Jul 24, 2021
RE: Cuisinart Vari-Speed CB-4. For no obvious reason, the blade mechanism on the bottom of the jar seems to have seized up and won't turn, causing it to sound as if it's striping the clutch. Fixable?
Yes fixable a number of ways Remove the blades and punch out the shaft. Clean it all and then reassemble it with lots of water pump grease (it's waterproof). Seizing happens because liquid goes down between the shaft and housing and sets. Or You can replace the blade assembly. The link below shows unavailable, but it shows the screw cap. https://www.pinterest.ca/pin/336644140882543457/ https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01e6oS01kQREtDDo5p3wJFsWtjgLw%3A1606770716337&ei=HGDFX9H3E_ew5NoPp4eroAw&q=Cuisinart+Vari-Speed+CB-4+blade+assembly Or you can replace the jug and blades https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk024qU5VgFCYIiGjqh6GkrGHAHCokw%3A1606770975275&ei=H2HFX_m1EI7u_QbH9oD4CQ&q=Cuisinart+Vari-Speed+CB-4+replacement+jug Or Contact Cuisinart direct
blenders parts & accessories - Cuisinart
www.cuisinart.com > ... > Parts & Accessories
Discontinued SmartPower Bar Basics™ 18 Speed Electronic Blender (CB-18BKSS). CB-18BKSS Discontinued SmartPower Bar Basics™ 18 Speed Electronic ... ‎CB-18BK · ‎CB-18BKSS · ‎SPB-7CH · ‎BFP-650 ..
2/17/2021 7:54:57 PM • Cuisinart... • Answered on Feb 17, 2021
20 Most Recent Cuisinart SB-5600 Supreme Super 600 60-Ounce 6-Speed Stainless Steel Blender with Glass Jar 60 Ounce suddenly stop working and no power on
At least on Amazon, the customer reviews are not so good ... only a 3.1 out of 5 for 38 reviews. Some of the poor ratings are that the unit just stopped working or a plastic housing part broke. You may have blown the motor. If it is still under warranty, and you have the receipt, you might consider shipping it back to Cuisinart ... but you pay for the shipping
2/19/2019 12:19:40 AM • Cuisinart... • Answered on Feb 19, 2019
Cuisinart CB 1400: motor won't engage. Blades turn (not frozen), power light comes on, but blender, pulse, or other functions don't work. Suggestions?
If the power light is on and the motor is not running the circuit board that starts the motor is defective. You could try to bypass the control board and apply power directly to the motor to verify the motor is ok and no blown fuse or circuit breaker. then you get to replace the circuit board or isolate a failing component on the circuit board.
1/1/2018 9:01:23 PM • Cuisinart... • Answered on Jan 01, 2018
Cuisinart BFP-703 Blender Logo
Popular Tags
20 questions posted
Top Cuisinart Blenders Experts
Mike Cairns
Mike Cairns
Peter Schmidt
Peter Schmidt
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
