20 Most Recent
Maytag Neptune Washer Questions & Answers
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
NEPTUNE WASHER BEEPS,,WANT TURN OFF OR START
When door locks like that next time. If you remove the top of the machine. Reach down inside on left side. There is a small wire cable that you pull up on. Will manually unlock the door. Then plug power cord in to wall. Power it on let it go through reset cycle and it will work properly again. However if you can't reach the latch through the top. Tilt washer forward and reach up from the bottom. If you get an F1 code it's low water pressure.
What does f1 E7 errors mean on neptune washer
There may be a problem with the Appliance Control Board, or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) minute. Power unit up by turning on the circuit breaker(s). Monitor the oven for one (1) minute to ensure the error code does not display again.
I have a 14 year old Neptune that run great except now no hot water.
There's a fill valve combination on most washers. On the simpler, cheaper models they're simple to change.
It's where the hoses connect, it's usually plastic, and there is a hot and a cold valve in the assembly. Hot opens for hot water, cold opens for cold water, and both open for warm water. apparently the solenoid valve on the hot water side has failed and the unit needs to be replaced.
Water flows out door while in use
Check the door gasket/seal for damage. Check to see if the door's mounting brackets are loose by lightly moving the door up/down. Also check the level of the machine to ensure that the frame is not twisted.
