20 Most Recent
Maytag Atlantis MAV6451 Top Load Washer Questions & Answers
Lid switch
In my experience a washer drains by reversing the motor, which activates a switch to open a solenoid valve in the drain line.
Your solenoid or the switch way be bad
Grinding noise when washing
Remove the back lower left access panel. Run the machine if you can to see if the noise is from the drain pump. This model is known for a bad pump design and has an updated design.
Here is the pump to order. Remove the 2 hoses and the 3 bolts to remove.
The part comes with a 365 day, any part, any reason return policy.
