20 Most Recent
Maytag MAH8700A Front Load Washer Questions & Answers
Pf error code MAH2400AWw
In my case it was a old connector harness located on your motor. Leads comming from tacho ( 2 red wires) were not passing thru harness. I rilpped them off and made solid but crimps.
Hope this helps a little.
Ive got a maytag neptune model# MAH8700AWW front
Would be the Inlet solenoid (this is effectively the valve that allows water to come in - that the inlet hose screws on to, and has a couple of wires going to it on the inside).
Replace carefully, with the power shut off, or simply turn the tap off when not in use :-)
It flashers f2 and now is flashing f15 and wont fdo anything
I have checked the tech sheet for your washer there is not any F codes only E codes. The two you have listed are for the stuck button. It sounds like someone was playing with the buttons and held the button for more that 30 secs. Then possible put it in child lock. If you need more help please let me know.
Maytag neptune mah8700aww wont drain, spin or put water in
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
