20 Most Recent Maytag LSE7806A Top Load Stacked Washer/Dryer Questions & Answers
Washer won"t fill with water
check your lid switch if its a top load
10/23/2021 3:47:08 AM • Maytag LSE7806A... • Answered on Oct 23, 2021
3answers
I have a model lse7806ace maytag stackable
Sounds like water valve is bad.
2/15/2019 11:55:42 AM • Maytag LSE7806A... • Answered on Feb 15, 2019
3answers
Where are the fuses to the dryer
There are 2 items named as thermal fuse item #6 (307473) on heater page and #30 (306604) on the motor page There are 2 other items #11 (303396) Hi-limit on heater page and #26 (306911) operating t-stat on motor page. On electric unit when one of the thermal fuses fails or the hi-limit shorts open. It's recomended to replace all. The primary reason the thermals fail is due to vent restrictions. Inspect and test vent exhaust behind dryer and to the outside is free flowing and not crushed or excessively long. Inspect lint and blower housing for blockage.
Ric
8/19/2018 4:58:29 PM • Maytag LSE7806A... • Answered on Aug 19, 2018
0answers
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode. This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
9/30/2017 12:57:45 PM • Maytag LSE7806A... • Answered on Sep 30, 2017
Model lse7806 ace
August 1997
9/13/2017 7:24:11 PM • Maytag LSE7806A... • Answered on Sep 13, 2017
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
7/29/2016 6:49:11 PM • Maytag LSE7806A... • Answered on Jul 29, 2016
0answers
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
2/15/2015 6:44:24 PM • Maytag LSE7806A... • Answered on Feb 15, 2015
2answers
Just bought a new (old) house and the Maytag
Check that you have 220 volts. or see that the timer is not set to Air Fluff ( no Heat)
you may have a bad thermostat, or a broken
heater coil. or a broken belt.
2/4/2015 10:01:41 AM • Maytag LSE7806A... • Answered on Feb 04, 2015
What would stop the washer in our LSE7806A from working?
Let's figure out what it's doing or not doing. From that, we can figure out how to make it do what it's SUPPOSED to do, or stop doing what it's NOT supposed to do. First... since it was stored, we can pretty safely assume that it was deemed to be suitable for storage - actually functional - when it was put there. Why else would one store it? So... tell us a little about what happens or doesn't happen. When you plug it in, connect the water, turn on the water, fill the machine with clothing, select a wash cycle, and turn it on... what happens? If NOTHING happens (the machine sits there dumb & silent), check the power outlet to be sure there's good power there. Plug a lamp into the outlet to prove it. If it hums and clicks but doesn't release any water to fill the tub, doublecheck your water supply. Prove that water does indeed come out of the taps. Also check the little screens in the water connections to the washer - are they clogged full of dirt and sand? Wasp mud nests (from storage)? If all looks well, look closely at the water control solenoids inside the washer. Check power there, verify solenoid operation. Next... if it fills but doesn't move, doesn't agitate, doesn't spin... check the motor. Verify power there, inspect the drive belt. If all is well up to this point but it doesn't drain, inspect the belt again and look closely at the pump. If it makes odd noises, look inside the back or bottom (or remove the top) and determine where those odd noises are coming from. You can track them down by ear (ears are marvelous directional finders for sounds) and hands and eyes. If you find the absence of power anywhere except in the power cord, look to the washer's control head. Trace power through it (for this a multimeter or AC test light is a handy tool). Keep us posted on what you're starting with and what you find.
8/1/2014 1:02:52 AM • Maytag LSE7806A... • Answered on Aug 01, 2014
My dryer seems slow up or stop then starts up again. Would that be the fuse?
Sounds like the belt is slipping, does it start slipping immediately? Try it without any clothes in it, it is definitely NOT a fuse.
7/2/2014 2:53:36 PM • Maytag LSE7806A... • Answered on Jul 02, 2014
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
434 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
  • Washing Machines
