20 Most Recent Maytag Neptune FAV9800AW Top Load Washer Questions & Answers
Why when washing machine ends cycle it keeps leaking water
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
8/16/2014 5:49:34 PM • Maytag Neptune... • Answered on Aug 16, 2014
Wire broke on lid switch can it be put back together
Is it the wire or the prong on the lock itself?
12/5/2012 11:41:19 PM • Maytag Neptune... • Answered on Dec 05, 2012
Washer is not spin drying
What does it do in the spin cycle?
12/4/2012 4:26:40 AM • Maytag Neptune... • Answered on Dec 04, 2012
Lidlock light blinksmhw700xgo
You will need to replace the wax motor on the unit. Here is the part to order.Below is a video to show you how to replace the wax motor.
11/19/2012 4:00:39 AM • Maytag Neptune... • Answered on Nov 19, 2012
My washer is locked won't open
Will Not Unlock• Press off. The motor control is not responding if ittakes 4 minutes to unlock. The motor control iseither bad or disconnected.• Unplug and reconnect power cord. Wait 20 secondsfor machine to unlock.• Check lid locked switch circuit. Circuit should beclosed at machine control.• Check for loose electrical connections at lid lock andat machine control board.• Push lid closed to make sure nothing from inside ispressing against it which may keep it from unlocking.• If necessary, remove clothes by disconnecting powerto washer, and open top cover with a putty knife.Here is the part to order.Regards,Richard Rothhttp://appliancecafe.com
11/13/2012 10:42:57 PM • Maytag Neptune... • Answered on Nov 13, 2012
Will not drain with cloths in it
Remove the front panel and check the drain hose from the tub to the pump for blockage. If the pump is not running at all you will need to replace the pump. Here is the pump to order.
11/5/2012 10:32:09 PM • Maytag Neptune... • Answered on Nov 05, 2012
Washer will not drain when filled with cloths
There usually something in the drain line, a sock many
11/5/2012 2:10:03 AM • Maytag Neptune... • Answered on Nov 05, 2012
Helllo, I have a Netune
i have the same problem! have you found a solution? please let me know... thank you
5/12/2011 10:29:42 PM • Maytag Neptune... • Answered on May 12, 2011
I keep getting the unbalanced
Thanks for choosing FixYa and welcome to the site. Since it is spinning fine and the shocks are good, I would start checking the floor that it sits on. If it was making noises or banging while spinning, it would be the drive or spin bearing. Since it is not, that is not the case. An easy fix to this is taking some small cut wood blocks and placing them on the surface of the washer. Since you apply pressure down on the front a tad, you should try placing the blocks at the back of the washer to try to establish balance. If the suspension checks out and the spin is fine, it may be the surface it sits on. I am sure the blocks will help.
4/22/2011 12:08:38 AM • Maytag Neptune... • Answered on Apr 22, 2011
We have a Neptune FAV9800AWW. It stops at 44
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
3/1/2011 8:11:33 PM • Maytag Neptune... • Answered on Mar 01, 2011
Maytag neptune fav9800aww has error for unbalance
I had the same issue with FAV9800AWW, the Quick Spin Test showed "Machine cannot spin because the unbalance circuit is always open or out of range." Removed the Tub Displacement Sensor, disconnected the wire harness to the sensor, and found corrosion between the contacts, especially on the 12V DC pin. When I cleaned it with isopropyl alcohol and soft brush, discovered that the trace had corroded away, and so the board was not receiving the 12V DC input. Also had checked on the pins of the blue/white (signal) and pink (gnd), and was always negligible millivolt reading. The part number is Whirlpool 12002194. Ordered it from Appliance Parts Pros after reading various reviews. I found it cheaper other places, but those places got too many poor reviews for my taste.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169373&diagram_id=28406005#d28406005
2/14/2011 4:03:17 AM • Maytag Neptune... • Answered on Feb 14, 2011
My Model LAT9800AAW won't fill, solution?
Hello
The first thing that should be checked is the water line for any clogs/obstructions, if thats fine then the water inlet valve has gone bad and needs replacement. Please get back to me if you have any other questions.
Kevin
11/9/2010 8:18:19 PM • Maytag Neptune... • Answered on Nov 09, 2010
Have a Maytag Washing machine model # FAV9800AWW.
have the pump checked for coins. inside on the right in the back of washer
8/24/2010 6:01:03 AM • Maytag Neptune... • Answered on Aug 24, 2010
My machine maytag doesnt function , i break open tap
board possible bad
1/14/2010 2:16:15 AM • Maytag Neptune... • Answered on Jan 14, 2010
Maytag Neptune FAV9800AW Top Load Washer Logo
42 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
when washing machine ends cycle keeps
  • Washing Machines
