20 Most Recent
Canon PowerShot A620 Digital Camera Questions & Answers
Card write protected
Thomas,
You will find a small knob on the card which makes it write protect. If the issue persist try any other card.
I need date stamp on
Thanks for the tip that was actually not listed in the the user manual.
This morning I encountered my slightly over one month (Dec 2013) old Keurig Mini B31 jammed up, I was only used 3 times so far...:( and feeling quite frustrated after wasted all 3 K-cups to try and find out what went wrong, initially thought it did not punch the hold properly, but still only a few drops of coffee came out from the brew, everything thing seems to work fine, it was just no hot water flowing down.
Tried to clean up K cup bottom needle with clip, but does not help, after browsing though fixya found that the top part needle also really need to clean up (not stated in the user manual), by using paper clips and finally it works again after all the dirt came out from the top part of hold puncher. My tips for people who did not use it daily /very often, they should:
- Clean up the top needle by running through a cup of water to flow it through the ground coffee excess after each brew was completed, otherwise it will tend to dried up and choke up before you know it.
- It help to shake it cup to have the top of the cup fill with some air, and it has less tendency to have the ground coffee in block up the top needle.
Hope this tips will help you to maintain a good cuppa!
All i want to know
No, you have to press the shutter release button to take the picture.Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. This sets the self-timer. Start the self-timer by pressing the shutter release button as usual.
How to tern on time
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
How can I download the software? I lost my CD.
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
PowerShot A620 Digital Camera: Cannot upload pictures from camera to computer...
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
