20 Most Recent Maytag SDE2606 Electric Dryer Questions & Answers
Maytag pye2300myw doesnt start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/5/2011 7:47:33 PM • Maytag SDE2606... • Answered on Sep 05, 2011
My Maytag dryer is approx. 15 years old. I have
It could be just a breaker if its a 220volt. Check your breakers first and clean you exhust tube!
9/3/2011 3:15:38 PM • Maytag SDE2606... • Answered on Sep 03, 2011
The dryer heats up but
Hi,There can be many reasons why your dryer will not start or turn...The most common causes are the belt breaking or jumping off, or the motor goingbad...Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...Dryer Repair - The Dryer is not TurningDryer Repair - The dryer will not startheatman101
8/23/2011 2:09:11 AM • Maytag SDE2606... • Answered on Aug 23, 2011
There is a scratching noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
7/24/2011 1:21:30 PM • Maytag SDE2606... • Answered on Jul 24, 2011
Stopped heating up
Hi mverschoor...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
7/6/2011 1:35:21 AM • Maytag SDE2606... • Answered on Jul 06, 2011
When it is turning, it is making a big noise
dryer making a vibrating noise when tumbling what is the problem?
4/19/2011 1:11:45 PM • Maytag SDE2606... • Answered on Apr 19, 2011
Its taking a long time
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
1/24/2011 4:42:24 AM • Maytag SDE2606... • Answered on Jan 24, 2011
Electric dryer haas two wires
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
12/23/2010 10:59:08 PM • Maytag SDE2606... • Answered on Dec 23, 2010
Squeek
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
12/23/2010 2:46:53 AM • Maytag SDE2606... • Answered on Dec 23, 2010
How do I replace the heating element in Maytag
1.Unplug the Maytag dryer from the dryer electrical outlet and pull the dryer away from the back wall.Use a putty knife to press in the locking clip between the front and top panels.While pressing the clip in with the putty knife,lift the top panel up to unlock it from the clip.Raise the top panel into the service position allowing it to rest on the back hinges.
2.Locate the door switch connection on the inside front right corner of the Maytag dryer.Press the locking tabs in with your fingers and pull the wiring harness away from the door
switch.With a Phillips-head screwdriver,remove the screw on both inside corners that secure the front panel to the sides. Lift the front panel up and away from the dryer.
3.Use a Phillips-head screwdriver to remove the four retaining screws that secure the drum bulkhead to the front of the side panels. Remove the bulkhead from the dryer.Reach under the drum and pull the idler pulley to the left to release the belt tension.Remove the belt from the motor and idler pulley. Lift the drum up and out of the dryer unit bringing the belt with it.
4.Remove the two screws that secure the heating element to the rear bulkhead with a Phillips-head screwdriver.Disconnect the heating element terminal wires by grabbing them with needle-nose pliers at the wire leads and pulling them off of the terminals.
5.Place the new Maytag dryer heating element into the dryer and slip the wire leads over the terminals.Secure the heating element to the rear bulkhead with the retaining screws.Lift the drum and belt and place the drum back inside the dryer cabinet.Route the belt around the motor and idler pulley.Shift the idler pulley back to the right to apply belt tension.
6.Reattach the front bulkhead to the dryer using the four retaining screws.Position the front panel into place and secure it to the sides with the retaining screws.
7.Bring the top panel back down and push the front corners in to engage the locking clips.Push the Maytag dryer back into its working position and plug the power cord back into the dryer electrical outlet.
8/28/2010 11:19:19 AM • Maytag SDE2606... • Answered on Aug 28, 2010
I have a Maytag Electric Dryer #sde2606ayw, when i
no thats wrong even if you can start it up by hand the motor can still be bad period. if there is no response and all relays test good behind the control panel cover then it is indeed ur motor. cha ching if u call a repair person.
7/29/2010 8:34:16 AM • Maytag SDE2606... • Answered on Jul 29, 2010
Wont turn on and run
SOUNDS LIKE THE BELT ON THE DRUM IS BROKEN, LISTEN CLOSELY AND YOU MAY HEAR THE MOTOR RUNNING THAT DRIVES THE DRUM.
3/10/2010 2:37:09 AM • Maytag SDE2606... • Answered on Mar 10, 2010
2answers
Dryer Drum Scrapping
You probably need to replace the slides:these wear down and cause the noise you are discribing.900bee5.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/16/2009 7:28:25 PM • Maytag SDE2606... • Answered on Oct 16, 2009
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
7/2/2009 10:01:13 PM • Maytag SDE2606... • Answered on Jul 02, 2009
Dryer won't heat
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
3/13/2009 7:20:11 PM • Maytag SDE2606... • Answered on Mar 13, 2009
Replaced belt & pulley, now drum won't spin properly
Belt mounted upside down. Slick side goes to tub on this odd ball machine. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3/8/2009 1:19:22 AM • Maytag SDE2606... • Answered on Mar 08, 2009
Maytag SDE2606 Electric Dryer Logo
33 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
help me fix lg dryer heat
  • Dryers
