20 Most Recent
Kodak EasyShare C643 Digital Camera Questions & Answers
Kodak C643 Error codes 111.0.0.-2
I do not know your camera but if there is a backup battery it may be the problem. Its a battery that looks like a watch battery only bigger.
LCD screen cracked
lcd's usually can be replaced check with your manufacturer....or ebay for replacment lcds and take it to a local center to get installed.
Where on the camera do you plug in the plug for
Your camera requires a "U8" type USB cable to connect between the standard USB port on your computer and the U8 jack on the camera.
A "U8" style USB cable & jack.
The U8 USB is similar in appearance to the USB "Mini" or USB "A" style jack. But will not mate to any other jack besides the U8 style. A typical USB Mini or "A" is shown below for comparison.
The camera shipped with the correct cable, but you probably didn;t notice there was a difference between it and other USB Mini cables - and simply grabbed the wrong one.
I hope this helps & good luck! Please rate my reply - thank you.
Lens
gentely try to opened with your fingers be sure not to touch the lent.
"Was this helpful?"
How do i charge the camera
You don't. The C643 can use standard AA batteries or a rechargeable battery pack. If you use rechargeables then you must charge them outside the camera using the appropriate charger.
Kodak easyshare camera C643. The
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
How do I remove pics
While viewing the picture, press the delete button (the first button above the big round cursor pad).
I hook camera up to computer but it says can not
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
