20 Most Recent Maytag MER6772 Gemini Electric Kitchen Range Questions & Answers
3answers
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad.  F1-2 would be for the lower oven and F1-1 would mean the upper oven.  If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price.  These are very easy to replace.  Should be located inside the oven in the upper right or left hand side.  It looks like a silver rod about 4-8 inches long and crimped on the end.  Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done.  Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above.  Hope this helps.
6/24/2020 11:17:14 PM • Maytag MER6772... • Answered on Jun 24, 2020
My upper oven on my maytag gemini double over
  • I have the same problem. Now the bottom oven wont get over 150 degrees!
3/9/2018 1:53:46 PM • Maytag MER6772... • Answered on Mar 09, 2018
The oven Is not heating up to temp -but now it not coming on.
You might have a weak oven igniter. It might not be pulling enough amperage to open the gas valve. If you have an amp meter you could test for 2.0 to 2.2 amps. I recommend saving money on the part and using a the Frigidaire igniter 5303935066
2/24/2018 4:39:57 PM • Maytag MER6772... • Answered on Feb 24, 2018
0answers
2answers
Ovens won't unlock after cleaning
Try cutting power to it for a few minutes
11/15/2017 12:50:03 AM • Maytag MER6772... • Answered on Nov 15, 2017
Maytag Gemini electric double ovens do not heat
More than likely the heating element is burned out.
9/28/2017 7:19:14 PM • Maytag MER6772... • Answered on Sep 28, 2017
After cleaning MER6775AAB, upper oven has stopped working
See if the top heating element is open. Also check the switch that feeds power to the element.
8/29/2017 2:01:27 AM • Maytag MER6772... • Answered on Aug 29, 2017
Can't turn off the timer once it's set
Push the Timer button then 0
5/16/2017 10:20:38 PM • Maytag MER6772... • Answered on May 16, 2017
My Maytag Gemini double oven/stove caught fire
yikes that sounds really scary there i hope everyone is ok
5/6/2017 2:52:00 PM • Maytag MER6772... • Answered on May 06, 2017
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
5/2/2017 5:37:25 PM • Maytag MER6772... • Answered on May 02, 2017
Lower bake element partially working
Is it a maytag?
https://m.youtube.com/watch?v=YReGvuOrSFU
4/7/2017 5:42:01 PM • Maytag MER6772... • Answered on Apr 07, 2017
0answers
3answers
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
12/3/2015 11:26:09 AM • Maytag MER6772... • Answered on Dec 03, 2015
Hot surface light stays on
It will stay on till it cools down. If it won't check short in the switch
6/2/2015 10:07:45 PM • Maytag MER6772... • Answered on Jun 02, 2015
Maytag MER6772 Gemini Electric Kitchen Range Logo
631 questions posted
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
bottom oven bottom element doesnt heat
  • Kitchen Ranges
