20 Most Recent Microsoft Xbox Console Questions & Answers
2answers
Gears of war 2 counters
It is not my duty to solve this problem.
it is epic's.
so the solution is never to buy another game by epic.
Problem Solved.
3/31/2021 2:40:29 PM • Microsoft Xbox... • Answered on Mar 31, 2021
Cant play video track due to unsupported codec
Dissaopinted to hear that you can not play videos on XBOX360. Let me provide you with link that in order to fix the issue;
http://www.online-tech-tips.com/computer-tips/can%E2%80%99t-play-mp4-files-on-your-xbox-360/
Try this and let me know the result.
Regards,
Anirban Mazumdar
7/26/2019 7:27:25 AM • Microsoft Xbox... • Answered on Jul 26, 2019
3answers
I was playing fifa 10 when my xbox fell and
you need new game....some games have an exchange program but i dont think EA is one of them
5/22/2019 6:24:11 AM • Microsoft Xbox... • Answered on May 22, 2019
My xbox will not read the games
Have you tried DVDs? If you have then you need to clean the disc head reader. That either involves taking it out or going on amazon and finding a head reader cleaning dvd. There may be a chance that a local best buy may carry them but it is a slim chance.
12/21/2017 6:51:45 PM • Microsoft Xbox... • Answered on Dec 21, 2017
9answers
Original xbox red ring of death
you have to take the xbox apart open the dvd/cd rome and clean the eye and the disk spinner then put it back together and it should work fine
1/13/2017 6:43:37 PM • Microsoft Xbox... • Answered on Jan 13, 2017
2answers
I get to picking my gamer tag and right after that
I would suggest giving Microsoft a call or going to xbox.com and getting them to guide you through setup and troubleshooting.
11/14/2016 7:02:11 PM • Microsoft Xbox... • Answered on Nov 14, 2016
3answers
My xbox360 games has ring on it
If the game has a ring around the disc like a scratch you want to go to game stop and have them buff it out . How your games got scratch ring on them if u hit or if you move the 360 from horizonal to vertical while theres a game in the dvd drive it will make a loud buzz sound like a blender with no ice in it and thats what put a scratch ring in your games . you can a skipped disc fix from game stop its called skip disc fixer . its a pate that you put on the game and gently buff out the scratch . For heavy scratches that r deep you might want to buy the game used.
3/5/2016 8:14:03 PM • Microsoft Xbox... • Answered on Mar 05, 2016
Error E 82
william, as you and I are probably the only 2 ppl on earth who still have these systems(lol) E 82 is a memory malfunction. It could be fixed by swapping out your controller, as the removable memory is found there. Also, make sure you have your A/V cords plugged in correctly. If you don't it can give you a false rrod. 24116750-xoi5c4krg4k0z0fzoraebupb-5-0.jpg
1/22/2015 11:43:24 PM • Microsoft Xbox... • Answered on Jan 22, 2015
2answers
Xbox 360 console doesnt read the disc all the time
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
1/5/2015 11:19:32 PM • Microsoft Xbox... • Answered on Jan 05, 2015
3answers
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color. FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
12/1/2014 12:13:40 AM • Microsoft Xbox... • Answered on Dec 01, 2014
manual
Fully red ring of light
I'm not sure the xbox live dashboard is still supported on the original xbox.
7/10/2014 1:55:16 AM • Microsoft Xbox... • Answered on Jul 10, 2014
14answers
Xbox won't read disks!!!!
If your xbox wont read the disc, it just says open tray, there is a very simple solution i discovered. You dont need to do anything complicated or fancy, simply make sure everytime you turn your xbox off the disc is out. Turn your xbox on without a disc in, let it get to your profile screen, then put the disc in. Works every time.
5/16/2014 6:12:09 PM • Microsoft Xbox... • Answered on May 16, 2014
Why does my Xbox randomly shut off on its own?
Sounds like it's overheating, try moving it to a well ventilated area
4/28/2014 12:41:29 PM • Microsoft Xbox... • Answered on Apr 28, 2014
My game is scrathed
If your game is scratched then try rubbing a bit of tooth PASTE (Not the GEL kind, the tube will clearly say which it is) on the scratch with a soft lint and static free cloth. Clean off with a very small amount of window cleaner. If this doesn't work you may have to look into getting a pro scratch remover kit, which may still not work.
Best of luck
4/10/2014 6:14:02 PM • Microsoft Xbox... • Answered on Apr 10, 2014
Original xbox flashes green then red the the number 12
Did you try turing the xbox off? if not then I would disconnect it and then connect it back in and see if this works. if not then it might be dying.
2/18/2014 12:36:01 PM • Microsoft Xbox... • Answered on Feb 18, 2014
When I turn my xbox on it turns back off
Now u try on and u may be u push hardly this way swich go inside take a knife and try switch out then try
1/20/2014 7:39:24 PM • Microsoft Xbox... • Answered on Jan 20, 2014
2answers
How do I Fix flashing green and red light
What error number does it have on the screen? It should be a white number in one of the corners of the screen. If you find out what it is, then select add more details in this question and say what the error number is.
12/1/2013 8:46:52 PM • Microsoft Xbox... • Answered on Dec 01, 2013
Microsoft Xbox Console Logo
1,498 questions posted
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
Xbox Microsoft
  • Xbox Microsoft
Most Popular Question
black white only
  • Video Game Consoles & Games
