If set has high pitched or grinding sound it is bad color wheel.
See attached photo. I can tell you how to verify this if the wheel is shattered.
Very common problem in these sets and if you Google the model number with "color wheel" after it you will see where to get it.
You Tube and other sites have video and written instructions for its replacement---THIS IS A DO IT YOUR SELF JOB and takes less than 1 hour. There are some pitfalls to avoid that are not in the video instructions and I can explain them to you.
Wheel turns at 14,000 RPM and the bearings in the tiny motor lock up and the wheel either shatters or turns too slow--set detects too slow and shuts lamp off.
If this information helped you, rate this solution as I do this here for free.
I can step you through the repair and tell you common pitfalls to avoid----EBAY SELLS A LOT OF THESE COLOR WHEELS.
sd tech------I AM HERE TO HELP.
