20 Most Recent Samsung HL-R6167W 61" HDTV Questions & Answers
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
2/16/2018 7:31:31 AM • Samsung... • Answered on Feb 16, 2018
My samsung hl-s6187w keeps shutting off. after 10-15 seconds
I would suggest looking over the power supply for bulging capacitors. Had the same issue and the power supply needed to be changed.
11/8/2016 8:56:01 PM • Samsung... • Answered on Nov 08, 2016
2answers
TV DISPLAY SAYS CHECK FAN #1, WHICH FAN IS THIS HOW DO I DO IT
Hello, I believe the Fan #1 on Samsungs is usually either the Fan that directly cools the lamp or the exhaust fan right next to it. But as a tech I would recommend that you carefully check all fans by taking the back cover off and finding the trip switch (it needs to be held down, usually blue that indicated the cover is on). when the tv is powered on and the screen comes on the fans should begin to work, you can visually inspect and replace then =) Hope this helps, let me know if you have any questions
7/5/2015 9:02:17 PM • Samsung... • Answered on Jul 05, 2015
2answers
HDMI & Component 1 port stopped working states no signal or weak signal
you will need the digital PCB model: HLR6167WX/XAA model: HLR6167WX/XAA part# BP94-01858A http://www.moduslinkptstvboards.com/search.php?search_query=BP94-01858A&x=10&y=10 Model: HLR6167WAX/XAA part# BP94-02084A see following website: http://www.shopjimmy.com/samsung/hlr4667wx/xaa?cat=225&q=HLR4667WX%2FXAA&tv_models=Samsung+HLR4667WX%2FXAA
3/23/2015 1:21:30 AM • Samsung... • Answered on Mar 23, 2015
Why TV won't turn on
First thing always try new lamp this may use 1 of 2 lamps 1) BP96-00826A 2) BP96-01073A remove the original lamp & it should have a part# on it. also, outside the lamp door, Samsung posts a label with the correct lamp part number on it. You can find lamps at the following website: http://www.shopjimmy.com/catalogsearch/result/?q=BP96-00826A
1/31/2015 8:24:53 PM • Samsung... • Answered on Jan 31, 2015
2answers
Samsung hl-r5078w flickering - higher resolution is worse
Sounds like a damaged color wheel.
11/25/2014 9:31:03 PM • Samsung... • Answered on Nov 25, 2014
Why do i have green and red colors distorting the piture, have already replaced cables
Try refreshing the display setting of your TV. It maybe just on the display setting.
8/11/2014 1:49:29 AM • Samsung... • Answered on Aug 11, 2014
Why do i have a green color across the screen
loose connection in one of the video cable either wire itself is bad or just need to reconnect them ,try different cables.
8/10/2014 4:25:25 PM • Samsung... • Answered on Aug 10, 2014
Tv turn off by it sejf temp light comes on
Hello, How long Ago did you replace your lamp? If this is not a lamp issue, it can most likely be a fan or thermostat malfunction (easy to replace, but hard to diagnose) If your lamp is new I would check around for any fans not spinning correctly. If they all seem to be working I would proceed to replace the heat sensor/thermostat. Hope this helps!
1/16/2014 9:14:14 PM • Samsung... • Answered on Jan 16, 2014
0answers
Samsung HL-R6167W 61" HDTV Logo
163 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
tv display says check fan 1 fan
  • Televison & Video
