20 Most Recent Fuji FinePix A400 Digital Camera Questions & Answers
Camera won't connect.
Try another cable or download you pictures directly from the card, inserting it in the sd slot in your computer.
6/3/2017 2:24:25 AM • Fuji FinePix... • Answered on Jun 03, 2017
When i turn on the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
9/15/2015 10:01:43 PM • Fuji FinePix... • Answered on Sep 15, 2015
Finepix 4.3f
What about this?
9/4/2012 1:45:09 PM • Fuji FinePix... • Answered on Sep 04, 2012
Need manual... is there a
You can download the manual at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/a500_e_manual.pdf
Yes, the filename says "A500." But it's the manual for the A400 and the A500.
9/21/2011 7:46:51 PM • Fuji FinePix... • Answered on Sep 21, 2011
The message focus error is
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
9/20/2011 11:02:17 AM • Fuji FinePix... • Answered on Sep 20, 2011
Not possible to tranfer data
What does your computer say about it? Does it pop-up a window that says something?
8/16/2011 1:05:50 PM • Fuji FinePix... • Answered on Aug 16, 2011
The lens won't go back in and the error
Hello
Regards
Andrea
6/14/2011 7:28:57 PM • Fuji FinePix... • Answered on Jun 14, 2011
Camera does not turn on.
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
6/6/2011 12:47:04 PM • Fuji FinePix... • Answered on Jun 06, 2011
CAN I GET THE SOFTWARE FOR FINEPIX bz VERSION 4.3F
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/26/2011 4:29:50 PM • Fuji FinePix... • Answered on Apr 26, 2011
Hi. I have a Fujifilm
Hello
Unfortunately a "focus error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
3/19/2011 9:25:23 AM • Fuji FinePix... • Answered on Mar 19, 2011
Card not initialized
If the 'CARD NOT INITIALIZED' error appears:
First check that the SmartMedia is inserted in the correct direction. You can also try wiping the gold-colored contact area on the SmartMedia with a soft cloth.
Remove the batteries from the digital camera, leave them for at least an hour and then reload the batteries and check whether the camera recognizes the SmartMedia.
If the 'CARD NOT INITIALIZED' error still appears, contact the store where you purchased the camera or the nearest FUJIFILM authorized service center in your country.
3/13/2011 8:56:18 AM • Fuji FinePix... • Answered on Mar 13, 2011
Cannot get my pictures onto my pc
What errors are you getting?
are you trying via cable or SD card.
if you deleted them you can use a free recovery program at:
http://www.piriform.com/recuva
or purchase it at:
http://www.runtime.org/
3/2/2011 6:26:42 PM • Fuji FinePix... • Answered on Mar 02, 2011
Lens stays in off position
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2/18/2011 10:25:43 PM • Fuji FinePix... • Answered on Feb 18, 2011
I have a A400 Fuji camera...and the pics will not
Pros avoid this very common problem by using a card reader...you should too.
1/14/2011 10:58:59 PM • Fuji FinePix... • Answered on Jan 14, 2011
How can i find the
You can download software and drivers from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a400#DriversAndSoftware
You might want to consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/27/2010 7:16:47 PM • Fuji FinePix... • Answered on Dec 27, 2010
My zoom lens is stuck
11/6/2010 10:32:53 PM • Fuji FinePix... • Answered on Nov 06, 2010
Zoom Error for Fuji FinePix A400 Digital Camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
9/30/2010 12:40:11 PM • Fuji FinePix... • Answered on Sep 30, 2010
Zoom error message is on
Hello
Regards
Andrea
9/27/2010 5:02:54 PM • Fuji FinePix... • Answered on Sep 27, 2010
Help please
try these:- connect it to pc and on it vaccum the barrel of lens changing mem. card and batt. for 2min.
9/11/2010 3:14:42 PM • Fuji FinePix... • Answered on Sep 11, 2010
Fuji FinePix A400 Digital Camera Logo
107 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
fujifilm
  • Cameras
