20 Most Recent
JVC Everio 25x/20GB Hard Disk Drive Camcorder Questions & Answers
Hdd error on cam, wht to do?
If you are unable to reformat the hard drive using the camera, and the USB drive is not showing up on your PC, there may be an issue with the hard drive itself. You could try using a different USB cable or a different computer to see if the USB drive shows up. If the issue persists, you may need to replace the hard drive.
Before replacing the hard drive, you could try resetting the camera to its factory settings to see if this resolves the issue. You can usually find instructions for how to do this in the user manual for your camera.
If none of these steps work, you may need to contact the manufacturer or a professional repair service for assistance.
Deleted Files?
First things first: DO NOT take any more photos or videos with your digital camera (memory card) that you want to recover files from in case you may quite possibly ruin your chances of recovery.Then here are some software programs that may help you out.For Windows -->
Data Recovery ToolFor Mac -->
Mac Data RecoveryHere are the steps:1. Connect your camera (memory card) PC or Mac which has installed the recovery program. 2. Scan for the lost files (photos, videos etc). 3. Recover them.
Changing shooting size to 320x240 on jvc everio hard disk drive
The everio series uses image quality setting for resolution. The lowest setting is economy so try it in that setting. If the images is still to large then this means the everio can't shoot any lower so you would have to edit it. A quicker solution I think for You tube posting is get a low end camcorder the the flip or one that shoots the video on a media card. These are lower resolution cameras and run around a hundred.
Can i use other braqnds of memory cards in the camcorder?
Yes. You can use any brand of memory card, as long as it's the correct type. Personally, I'd stick with the major brands, but I use several different brands with my several cameras and none of them have ever caused any problems.
Screen won't light up in
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
How do i download my video camera to my computer
The camcorder has an extirely separate storage compartments functioning as an entity of its own. Capture the pictures or videos to be stored on the cameras builtin hard disk. Once the shoots acquired are ready to be transmitted into the computer require USB cables provided with the camera at acquisition. An unavailble USb cable is acquirable from retail to achieve the link for transfer to take place. Plugging the camera to the computer with cables provided should produce transfer results. The computer always request to transfer what has been acquire in the cameras disk. A permittion response usually a click of button would require naming the photos or videos about to be imported into the computer. provide a name to the transfer media and also choose from the pop up menu automatically displayed an area on the computer. For example, the computers pictures or briefcase allows to store similar files easily retrievable with computers that have several data files or disk storage media.
