20 Most Recent
Konica Minolta DiALTA CF910 Copier Questions & Answers
Malfuntion Call a technician Code C0500
FUSER CODE. NOT SURE ON THIS SAME MODEL BUT ON OTHER DiALTA'S YOU NEED TO DO WHAT IS CALLED A "WARM RESET OR WARM REBOOT". tURN COPIER ON AND FIND A VER SMALL HOLE (PAPER CLIP SIZE) ON KEYBOARD OR SOME TIMES ON RIGHT HAND SIDE OF KEYBOARD, SOME TIMES SMALL SQUARE HOLE. STICK PAPER CLIP IN HOLE AND THAT WILL BRING YOU INTO SERVICE MODE. PANEL WILL SAY TROUBLE CODES, DEPRESS. TURN COPIER ON AND OFF AND SEE IF IT GETS YOU GOING. IF PROBLEM COMBES BACK YOU HAVE A BAD FUSER, EITHER FUSE, THERMISTER OR CONNECTORS.. GOOD LUCK
What does the error C3310 means
I am going to start by saying this. I am suggesting to you what I would do, I am not responsible for what you do to your machine.
This is an older machine. The code is saying there isn't a good connection between the 2 boards in the back of the machine. FIRST, TURN THE MACHINE OFF AND UNPLUG IT FROM THE WALL! I cant stress that enough. Then, I would take the back cover off of the machine. Then, lightly press each and every cable in, to try and reseat the connections. Try turning it back on, staying clear off the boards in the back. If that doesn't work, turn the machine back off and unplug it from the wall. Then go back to the boards. Try unplugging each and every connections on both boards. Just unplug one at a time and plugging it back into the same hole.
If this still doesn't work, you have a bad PWB-B board.
C0920 problem
1 paper tray malfunction.Open and close front door.
Hw to make number of
just before pressing copy button just press the number of copies you need and go.
good luck
NEED HELP REDUCING AN 11X17
Hi on the machine there is a zoom setting you can just select 11x17 to 8.5x 11 and this will reduce it
automatically for you
I have a Konica Minolta CF-910 which has an error
this is an error with the fuser unit temp there is a reset switch it is under by the interlock swith you should be able to reset it if it keeps coming up you will need to replace parts on the fuser unit it is an issue with low temp
