20 Most Recent Konica Minolta bizhub 161f All-In-One Laser Printer Questions & Answers
2answers
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
6/24/2019 7:12:34 AM • Konica Minolta... • Answered on Jun 24, 2019
Error 2703 en bizhub 600
If the problem persists initialize the Fax board (Service Mode =>Fax =>Initialization
4/17/2019 5:00:20 PM • Konica Minolta... • Answered on Apr 17, 2019
I have message call service(M1) So how to clear?
firstly press menu then press quick setting then twoo time press left arrow then again press quick setting then press left aroow and after this press right arrow service mode will open at ur machine select "Maintenance Counter" now in this option select, 0 and press ok.
5/19/2017 1:17:28 PM • Konica Minolta... • Answered on May 19, 2017
2answers
Maintenance Call (M2)
maintence call(m2) call service
5/7/2017 8:43:04 AM • Konica Minolta... • Answered on May 07, 2017
Eror code M2
on a Bizhub 161f? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/19/2016 4:53:42 AM • Konica Minolta... • Answered on Jun 19, 2016
Desbloqueo del codigo 3806 en konica minolta bizhub 501
Power off the machine, ensure the sub power switch is on that is the one on the control panel, now hold down the utility/counter button and turn on main power switch, wait to see trouble reset on screen the touch get OK then power off. Wait 10 second power on. if code comes back replace the fuser unit do not reset again or the machine can catch on fire the code you are resetting is for the fuse the HOT Part, that could ruin a perfectly good day Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/25/2015 9:57:05 PM • Konica Minolta... • Answered on May 25, 2015
I am getting an error message that says error C14A3. How do i fix it?
The bright that normally come on under the big glass is having issues, replace the scanner assembly can't just get the lamp. try this web site for starters Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/25/2015 12:39:18 AM • Konica Minolta... • Answered on May 25, 2015
Admin password for KM 161f
found it. it's "sysadm"
1/29/2015 11:38:57 AM • Konica Minolta... • Answered on Jan 29, 2015
Driver 7 32bit
hi its link for driver http://www.konicaminolta.eu/en/business-solutions/support/download-center.html and you may find here drivers
4/21/2014 8:36:58 AM • Konica Minolta... • Answered on Apr 21, 2014
Code c0500
C0500 is a warm-up error on those little machines. Try holding the stop button while switching on, that should reset the code. It sometimes happen if it's kinda cold, or when the power dips. If the code comes back, you'll have to replace the fuser unit.
10/21/2013 5:47:21 AM • Konica Minolta... • Answered on Oct 21, 2013
0answers
Errorcode#c3451
maintenacne call (m1)
6/3/2013 4:58:34 AM • Konica Minolta... • Answered on Jun 03, 2013
When scanning a doc it shows up in email as a gif and not a tiff/pdf? Why?
That is just the format it saves it in. Open the document and tell it to save as and you can change the: "Save as type:" to the type of document you want.
4/1/2013 4:50:24 PM • Konica Minolta... • Answered on Apr 01, 2013
Dell Printer 2155 replace PHD
Open the front cover.Pull out the PHD carefully and install the new one.
2/15/2013 1:08:31 PM • Konica Minolta... • Answered on Feb 15, 2013
Konica Minolta bizhub 161f All-In-One Laser Printer Logo
58 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
message call service m1 clear
  • Office Equipment & Supplies
