20 Most Recent
Konica Minolta PagePro 1390MF All-In-One Laser Printer Questions & Answers
My Konica Minolta 1390Mf says open front cover and
Normally when you get a remove paper jam and there is no paper, it is because the paper didn't make it out of the tray. Open the front door and remove your toner/drum unit. If you look inside you will see a gray half circle roller, try cleaning this roller with mild detergent. Do not use alcohol, this will dry out the roller.
Lamp error
How do you know its a lamp error?. if it is the scanner lamp its located under the glass. And you replace the whole module not just the lamp, or is it the fuser lamp, you just replace the whole fuser section which is the Hot part. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
1390 null tag error
Navigate to the site below, the steps are listed under:
Advanced Computer User Solution (manual restore):
