20 Most Recent
Whirlpool GHW9150 Duet Washer Questions & Answers
Whirlpool duet washer fabric softener dispenser does not empty
Hi thereI wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.I hope it workskolbrun
3/21/2015 11:42:12 PM •
Whirlpool...
Answered
on Mar 21, 2015
Too much water going to the tub
Many top load machines have a big metal water level sensor up in the electronics bank with a plastic tube that senses pressure as it fills. There is a small half inch screw in the center of it that is adjustable to set the water level on that thing. The sensor sort of looks like a car EGR vacuum recycler valve. Check Google images of washing machine water level sensors to see if your has it, as it is fairly universal. Make sure your pressure tube is not loose or kinked.
3/12/2014 6:59:21 AM •
Whirlpool...
Answered
on Mar 12, 2014
Does not rinse
see the cause and fix it. God bless youf the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
9/23/2012 4:49:06 AM •
Whirlpool...
Answered
on Sep 23, 2012
GHW9150 will not start, door
This means that the CCU on the rear of the washer has an electronic glitch. Try unplugging the washer for several minutes if this does not work the CCU would need to be replaced.
To do so remove the top of the washer. Three screws hold it down. The ccu is on the top of the washer. Remove the wires and place on new.
Let me know
7/5/2012 1:25:58 AM •
Whirlpool...
Answered
on Jul 05, 2012
