20 Most Recent
Amana NAV5805A Top Load Washer Questions & Answers
Amana washer - not agitating
there is a motor for the agitation that eventually fails in all washing machines. Due to the fact that this is a 115v set up, you need to use a multimeter to diagnose. There is also a belt that runs from the motor but that rarely is the case.
How do I get to
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Not spining out good
Make certain that the spin speed is where you want it (e.g.: high spin). Also, make certain that you aren't overloading the washer. A heavier load will slow down the spin.
You may have a worn drive belt (loss its tension on the pulley). Contact an appliance service company.
Load dial knob completely broken, cant even get a
yes . but do not force . take your time . pull off one of the other knobs to see style. or type . probably a (D) shaft . I would try a L tip puller ( it;'s like a ice pick with a 90 on the end . and try it from the front . / the try from back /the sw may be type that 1/2 a turn and it will come out ot work on . or it might be that 2 screws mount from front .. give it a good try . there is no right way . and when you get it done you can tell us how proud you are .." i did it on my one "" mm doesn't that feel great . mm
Lwd27aw belt replacing
PULL THE FRONT LOWER PANEL, BELT SHOULD BE IN FRONT OF YOU. YOU MAY NEED TO DROP THE MOTOR TO GET THE BELT ON
Putting belt on top load amana washer moder #unknown
There is a large pulley directly under the washer drum that runs the
transmission. There is a small one connected to the motor shaft, and a
third which is attached to a spring-arm and acts as a tensioner.
Pay attention to the direction the tensioner moves. The back of the belt should go against the inside of the tensioner when it is released.
The easiest way I've found to get the belt back on is to thread it around the small pulley, and tensioner, then start it on one side of the large pulley, and rotate the large pulley to allow the belt to thread onto it.
Hope this helps.
No drain untill you hold timmer knob out
ok,no doubt you need a new timer.when you push on the timer thats causing the contacts in the timer to connect.Ive seen folks wege a hard pice of paper under the timer dial.timer around 100$
