20 Most Recent AOC A15X221 15 in. LCD Television Questions & Answers
0answers
Re: A15X221 I have Direct tv and get a signal
Go into the menu to Channel tab. Set the input mode to Cable.
6/26/2016 12:42:15 AM • AOC A15X221 15... • Answered on Jun 26, 2016
AOC A15X221 have picture no sound
Try a factory reset: 1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote) 2. Using the other hand, press the Power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and Enter. 5. Power off and reboot the TV and Computer. 6. Run channel auto-scan to regain the picture.
6/26/2016 12:38:39 AM • AOC A15X221 15... • Answered on Jun 26, 2016
Screen says out of range
This can happen if the output from the computer has the resolution set higher than your monitor is capable of displaying, or the refresh rate is higher than the monitor can display. Set the refresh rate to 60Hz. Try connecting a friend's monitor temporarily.
6/26/2016 12:26:21 AM • AOC A15X221 15... • Answered on Jun 26, 2016
4answers
Can't get sound to play on my AOC LCD from my XP computer.
did you have an installation disk?? If so it may not have loaded in the setting to make the sound card accept the monitor..Or simpler--is the right wire plugged into your computer for the sound??
color codes don't always match for generics.
6/25/2016 12:52:56 PM • AOC A15X221 15... • Answered on Jun 25, 2016
AOC A15X221 15 in. LCD Television remote loss and my tv is mute mode
Try unplugging the TV from the AC outlet for at least 10 minutes then plug it back in. Let me know how this work out.
6/4/2015 2:55:57 AM • AOC A15X221 15... • Answered on Jun 04, 2015
Input not supported
screen resolution probably the problem if you have another moniter like a crt(which can support higher resolution) change it to the lowest level resoultion and then put in you lcd moniter and see if it works and if it does change the resolution to a comfortable level for you
1/7/2014 3:27:11 PM • AOC A15X221 15... • Answered on Jan 07, 2014
AOc tv codes
0098/0678/0564/0008
8/30/2012 3:18:09 AM • AOC A15X221 15... • Answered on Aug 30, 2012
2answers
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
5/28/2012 1:42:38 PM • AOC A15X221 15... • Answered on May 28, 2012
Appears on screen"input not supported"
Start windows in safe mode - press F8 on the keyboard during the boot process and wait for the startup options menu to appear. Select Safe mode and see if this works. If so, then once in safe mode, change the display settings to a lower resolution. the maximum resolution for this monitor is 1024x768. Set it to 800x600 to see if it works at the lower resolution first.
3/1/2011 12:58:52 PM • AOC A15X221 15... • Answered on Mar 01, 2011
2answers
How to download my voice record to youtube from
create your account there or sign in with gmail account after sign in on youtube you can see a yellow upload switch under your sign out link click on upload and browse your video for upload write your comments there for your video then save after you save your video,, youtube guys take few time to check your video it is copyrighted or not when they approve your video you can see your video on under your account,,, video
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
3/30/2010 6:27:49 AM • AOC A15X221 15... • Answered on Mar 30, 2010
How to turn the montor ON?
More info needed, i.e. what make and model monitor is it? Regards
12/6/2009 2:46:05 PM • AOC A15X221 15... • Answered on Dec 06, 2009
Pressing the power button on the remote control
You have weak capacitors in the power supply.If you are handy with a soldering iron you can take the back cover and follow the power connector up to the p.supply circuit board. there you`ll see cylindrical shape capacitors with values like 220mfd/35v written on them, look for rounded top on some of these(there might be 3or 4).they need to be replaced,find them in electronic stores and observe polarity when replacing them.and don`t forget to always unplug the set before working on it. good luck
11/3/2009 2:48:37 AM • AOC A15X221 15... • Answered on Nov 03, 2009
AOC A15X221 15 in. LCD Television Logo
34 questions posted
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Televison & Video
Most Popular Question
appears screen input not supported
  • Televison & Video
