20 Most Recent
Konica Minolta Bizhub C 353, Bizhub Color,bizhub C 253,konica,bizhub C 450,c 550 Questions & Answers
BACKGROUND BLUE
may be
-paper already have a blue back ground or any color.
-from CIS (camera) or Main board.
you can check option named drop out color.
I have documents hung in que that has machine not printing
need details - what OS, is it hardwired via USB or connecting via network or wifi - could be port is blocked in your router's firewall, could be port is blocked in the PCs firewall, could be lots of things. Not sure what you mean by going online to clear documents - online where? is this a "cloud" printer? try shutting off printer for 20-30 sec then restart it - that may clear docs stuck in it's internal memory. going to need more details if you expect anyone to offer more detailed troubleshooting.
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
