20 Most Recent Estate TEDS840JQ Electric Dryer Questions & Answers
How to assemble belt
Hello Denise, I have seen this problem many times. The sneakers by themselves in the dryer cause a shock effect , when the weight of the sneakers tumbling onto the drum overloads the skinny belt and the belt breaks every time. Usually. if you dry the sneakers along with other clothes or towels this will not happen.
2/27/2014 5:04:19 PM • Estate TEDS840JQ... • Answered on Feb 27, 2014
Belt replacement
This article I wrote will assist you to replace the belt How Replace The Belt on Your Whirlpool Dryer Your dryer is made by whirlpool and this is how to replace the belt
1/30/2014 9:46:19 AM • Estate TEDS840JQ... • Answered on Jan 30, 2014
Motor will not run
The heater is not supposed to come on unless the motor is running. The cent switch inside the motor powers up the heater. You must have a shorted element and that is probably what took the timer out as well. Here is HOW IT WORKS Another interesting video I made is estate dryer no heat which I show where the fuse and all is. The fuse by the way ties into the door switch and is mounted on the blower housing. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/9/2013 4:27:58 PM • Estate TEDS840JQ... • Answered on Dec 09, 2013
I bought a used Estate
Go to this website to see how to connect your dryer cord
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
12/9/2013 4:06:08 PM • Estate TEDS840JQ... • Answered on Dec 09, 2013
TEDS840JQ no heat
It probably has a bad timer. To check the timer set your meter for ohms or tone if you have tone. Connect a test lead to the terminal that connects to the large red wire from the heater. Now check for continuity between that point and all other terminals on the timer. if ya cannot get a reading the timer is bad. Here is my video: Estate Dryer No Heat If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/2/2013 4:21:31 PM • Estate TEDS840JQ... • Answered on Dec 02, 2013
How can you tell if the thermal fuse is defective
You can check it for continuity. But if the dryer won't run and you have power to it, that is also a sign that the fuse is bad.
11/6/2012 9:06:00 PM • Estate TEDS840JQ... • Answered on Nov 06, 2012
My estate dryer worked for a few minutes after I plugged it in, however I smelled something like it was burning, so I stopped it and now it will not come back on. any suggestions?
First, check to see if the door switch is good. Push and release it by hand and you should hear a click. If that is good, then the "thermal fuse" has gone out and will need to be replaced. Here is the fuse.Here is a video to show you how to replace the fuse.
10/20/2012 3:21:25 PM • Estate TEDS840JQ... • Answered on Oct 20, 2012
Lint trap not collecting lint
the lint trap is a thin gauze material and should trap plenty of lint---are you sure its there or in place properly?
9/23/2012 1:59:57 AM • Estate TEDS840JQ... • Answered on Sep 23, 2012
Dyrer is making a thumping sound when running when empty.
the rollers on the drum are going bad
7/23/2012 5:32:20 AM • Estate TEDS840JQ... • Answered on Jul 23, 2012
How do you change a dryer belt
That is the same model dryer I bought for my parents eight years ago. You will have to contact Whirlpool for a repair guide.
4/22/2012 8:26:00 PM • Estate TEDS840JQ... • Answered on Apr 22, 2012
How do you change dryer belt?
remove outer housing belt will be attached to rear of drum.Good luck its no fun
4/22/2012 7:27:38 PM • Estate TEDS840JQ... • Answered on Apr 22, 2012
Timer will not advance even after replacement.
Does the timer advance in timed dry setting or will it not advance no matter where its set??
If it does advance in the timed dry (or air fluff setting) but just does not advavce when dryer is set to autodry setting the problem is going to a poor air flow problem and the lint filter/blower housing should be checked for lint build up also the vent tube should be checked for a blockage
If the timer does not advance at all on any setting ya need to check the wiring of the dryer for a possible burnt wire on the neutral side
GENE
11/2/2011 10:14:31 PM • Estate TEDS840JQ... • Answered on Nov 02, 2011
Drier dries too slowly. it does heat up but i
You do not state if you are using a machine with an automatic drying sensor. If so the calibration of the sensor is off. Try setting the control to a dryer setting. If you are using it by time only, it would appear there may be a blockage in the air outlet. Check the damper flapper at the output of the air vent. It might be partially stuck closed thus reducing the air flow around the clothes. Just a thought that your washer spin dry may not be sufficiently spin drying the clothes and so that the clothes are overly wet when put into the dryer..
10/5/2011 2:45:31 AM • Estate TEDS840JQ... • Answered on Oct 05, 2011
Dryer not getting hot enough
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...heatman101
8/23/2011 2:07:50 AM • Estate TEDS840JQ... • Answered on Aug 23, 2011
Dryer has power- light is on- cycling the door
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
8/12/2011 11:59:52 AM • Estate TEDS840JQ... • Answered on Aug 12, 2011
What is this feature-"Wringle Prevent"
What the wrikle prevent does is after cycle is done if you dont go take clothing out right away is will tumble the drum without heat for 30 seconds every 10 minutes till the door is opened so the clothing doesnt sit there and wrinkle but gets tossed around lightly so wrinkles dont set in.
Gene
8/8/2011 3:55:43 PM • Estate TEDS840JQ... • Answered on Aug 08, 2011
Dryer was working fine until I turned off the
Hello Steve,
I am a bit confused because the model you selected is for a electric dryer which should have a dedicated outlet/breaker only for the dryer
I am going to assume it's a gas dryer and the trouble is with the outlet,to verify this plug a know working object into the outlet and see if it works
Even if the part in the dryer part that cuts the circuit to the motor if it's bad(thermal fuse) has no bearing on the drum light and that should work if power to dryer
Gene
7/29/2011 9:58:00 PM • Estate TEDS840JQ... • Answered on Jul 29, 2011
Where should i look for the belt location inside
If you need to find parts or manuals for the dryer, go to Google website and type in you model number and then type in what you need manuals or parts. More then likely your belt came off the idler pulley.
5/11/2011 3:57:24 AM • Estate TEDS840JQ... • Answered on May 11, 2011
The drum stopped turning.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
3/6/2011 3:23:08 AM • Estate TEDS840JQ... • Answered on Mar 06, 2011
Estate TEDS840JQ Electric Dryer Logo
91 questions posted
Top Estate Dryers Experts
Paul Carew
Jorgie  the...
Jorgie the...
Are you an Estate Dryer Expert? Answer questions, earn points and help others
View Most Popular
Estate Dryers
  • Estate Dryers
Most Popular Question
motor will not run
  • Dryers
