20 Most Recent Hoover Nextra HNL 3166 Z Front Load Washer Questions & Answers
Hoover nextra 7 program stops part way though
A possible fault that is consistent with your symptoms is that the water level sensing is confused. This is usually a column of water in a plastic tube bearing on a diaphragm switch which operates when the weight of water is sufficient to trip it. The water level is adjusted by a dial which alters the pre-loading on the switch, meaning it needs a bigger or lesser column of water to trip it. If there is a leak in the tube, that would account for the water level trying to cycle. Any water underneath the machine? If so it is a good indicator that is the right track. If not it still may be that fault, but the leaking water is just not making it to the floor. It is normal that the program suspends for filling, and it will not give rise to an error. Also normal is flow through the detergent drawer whenever there is a fill cycle. What is not normal is the repeated fill cycles. Also investigate the actual switch associated with the level sensing. It might have bad contacts. Please post what you eventually find the fault to be. Helps everyone, especially those trying to diagnose at a distance.
2/3/2018 6:51:26 AM • Hoover Nextra... • Answered on Feb 03, 2018
When any of the "normal" wash programs are
you will need to download the user manual from the manufactures website it normally free and look in the troubleshooting guide eric
12/27/2017 5:43:45 PM • Hoover Nextra... • Answered on Dec 27, 2017
Hi I have a Hoover optima 1400 nextra 8 front
FLASHING what ~ please?
12/25/2017 12:26:11 AM • Hoover Nextra... • Answered on Dec 25, 2017
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
6/20/2016 7:16:06 AM • Hoover Nextra... • Answered on Jun 20, 2016
3answers
Washing machine
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question.
2/12/2016 11:41:44 PM • Hoover Nextra... • Answered on Feb 12, 2016
Makin a a loud noise likethe motor going out
How old? warranty? Owner's manual, Troubleshooting may help. Contact Manufacturers Customer service. If you are nice, they usually are helpful. It's possible something is caught on the edge of the drum and overloading the motor. Usually, the motor has an overload switch which will cause it to shut down to prevent burn out.
3/4/2015 4:11:07 PM • Hoover Nextra... • Answered on Mar 04, 2015
2answers
Hi the belt on our hoover hnl 6166 nextra will not
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
2/14/2015 9:04:01 PM • Hoover Nextra... • Answered on Feb 14, 2015
How do I change pcb on Hoover Nextra HNL 2126 please ?
make sure u photograph were all the wires go back on with ie ure phone
2/13/2015 2:49:33 PM • Hoover Nextra... • Answered on Feb 13, 2015
Black oil in washing
Black oil comes from a leak in the washer transmission seal.
12/6/2014 5:17:10 AM • Hoover Nextra... • Answered on Dec 06, 2014
2answers
My hoover washing machine wont spin and is full of
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
1/31/2014 2:03:56 PM • Hoover Nextra... • Answered on Jan 31, 2014
Washing machine fabric conditioner compartment
This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
8/5/2013 5:39:18 PM • Hoover Nextra... • Answered on Aug 05, 2013
0answers
Hoover Nextra HNL 3166 Z Front Load Washer Logo
115 questions posted
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
change pcb hoover nextra hnl 2126 please
  • Washing Machines
