20 Most Recent
Tasco 750 Monocular Microscope Questions & Answers
How much is this model
Amazon has used ones for about $25. New they are not worth that much more. They are designed more as a toy, then a real microscope.
3/12/2019 11:42:23 AM •
Tasco 750...
Answered
on Mar 12, 2019
Microscopy; Relatively large spots on unknown surface obstructing view
HELLO..
There is five part in microscope
1. Eye piece
2. Binocular tube
3.Objective
4. magnification changer or joom accembaley
5. illumination segment
Try to make it out which part is gives a effect to your vision.
as per my suggesition illumination asembely you just clean it first.
keep in touch
regards
INDRAVIJAY
5/19/2013 9:28:54 PM •
Tasco 750...
Answered
on May 19, 2013
I picked up a Bushnell 1200 power microscope at a
You will need to focus in on the slide. There should be 2 1" diameter knobs on either side of the stand, and just to the rear. Those knobs control the height of the stage (where you slide sits). Slowly raise or lower while looking into the eyepiece. At some point something should be see, if the microscope is working properly.
Sometimes it is easiest to start with the lowest magnification. On the outside of the objective (little lenses hanging down that can be rotated) there should be some numbers written on them (usually 4, 10, 40). Those numbers reference your magnification. If you multiply that number by the eyepiece (10) magnification, you will get your total magnification, so start out with your 4x. It will give you the largest field of view, so it is great for finding whatever it is that you are looking for on your slide. It is also the easiest one to get focused. The higher you go in magnification, the smaller the field of view, thereby the more difficult it is focus in on your sample.
9/5/2011 8:05:52 PM •
Tasco 750...
Answered
on Sep 05, 2011
My tasco microscope light will not turn on and the battery pack
sometimes when a battery causes corrosion inside something, you can clean off the springs or contacts where the battery goes. if i can, when that stuff happens i use sandpaper or something like that to clean the contacts. you cant always get sandpaper where you need it though. just try to find something to like scrape stuff off if its on there
5/1/2010 5:01:41 AM •
Tasco 750...
Answered
on May 01, 2010
Manual for a microscope
Try Ebay--may have to buy the micro aswell but it won't cost much,have you tried the Tasco website in case a free d'load is avail?-kind regards martin r
3/27/2009 11:50:31 AM •
Tasco 750...
Answered
on Mar 27, 2009
Fixing one
You must detach the bottom cover of the base of the microscope by taking off the 4 or 5 screws that keep it attached. That should reveal the wiring to the socket and bulb base.
12/22/2008 10:15:21 PM •
Tasco 750...
Answered
on Dec 22, 2008
Manual
I found out that Tasco microscopes have been discontinued quite some time ago. A Company called Bushnell 1-800 423-3537 who gave me the number of ABO 305-859-2010 Tasco microscope 750X # 60750-0 call after 3pm. They do not have my manual but can answer questions or send a similar manual. I have to call back stiil hope this helps. Zoom
3/19/2008 4:53:08 PM •
Tasco 750...
Answered
on Mar 19, 2008
Problems with viewing under low magnification (20x) only red stain
hello..
For the red colour partical your illumination angle should be 0 degree.
As per you exepirience you are getting red at low magnification and not getting at high magnification. at the higer magnification the light deviation you can apriciate more then lower.
try to adjust your light source focusing lenc at higher magnification so at the lower it will be more better,
for the further problem you can contect me any time,
regards.
INDRAVIJAY
3/10/2008 4:26:13 PM •
Tasco 750...
Answered
on Mar 10, 2008
Microscopes
sir,
Diffrent company having their own system for microscope arm balacing.
Tell me which one microscope you have.
Auxillary arm or microscpe body sloly come down ward.
tell me problem is consult with which part..
INDRAVIJAY
3/10/2008 4:02:28 PM •
Tasco 750...
Answered
on Mar 10, 2008
Optic lens tube separation
sir,your microscope tube with the eye piece is screw joint with microscope body. Rather part is friction fitted as well as there is a proper place to mount it.you can do the gluing but first of all be clear that part should be not a movebale part other wise you will have dificulty for fine focusing.
for the further quotation dont be hazitate,
INDRAVIJAY
3/10/2008 3:49:47 PM •
Tasco 750...
Answered
on Mar 10, 2008
