20 Most Recent
Bushnell Voyager 78-9945 Telescope Questions & Answers
We just got our Bushnell
I think I already answered this question. Eyepieces are NOT assembled they are one piece like this picture:
http://www.amazon.com/Celestron-93342-17MM-Plossl-Eyepiece/dp/B000YKZKNI
They simply slip into the hole of the focuser -- straight in. The larger the number written on the eyepiece the LOWER the magnification.
In the picture above there is a metal triangle holding the tripod legs apart-- it is called a "tripod spreader" or a tripod "tray"-- used for holding eyepieces and other small pieces of equipment while you are using the scope.
Hope that helps you.
I really do not know
1. Please read menual proper.You can see live demo through company website also.
2. Start with lower resolution eyepiece.For thet you see the meximum number on eyepice.Than you start first to see moon.Because mon is a brightest obect of the sky 7 easy to find.than you go planet etc.
3.Finderscope is a taegt shooter.Please switch of finderscope.You can see two red dot in the finderscope. Than you aline the object ine sky with two red dot. Move the telescope up to in line(Obeject which you want to see and two red dot).
Now you can see in the eyepice to megnifing image of object.
Bushnell Voyager 78-9675
Please you any hobby shop. All telscope mostly similer.all eyepiese is adjust with any telescope.
Don't worry if you lost finderscope ot finderscope adjustment.This unit is support to find object only.You can find diectly.
Happy sking.
Solution to not seeing thru
1.Start sky watching with moon .You try to locket moon first.See proper how change in vision using focusing knob.
2. Than you try to see Jupitor,Seturn etc.
Can't see out of lense. Do you take both end caps
Here are all the manuals. Find your telescope- look down this page:
http://www.opticsplanet.net/bushnell-warranty.html
The MIRROR is the bottom of the telescope. The focuser is on the side of the tube and should be th UP end of the telescope. Remove the lens cap.
I need a manual for
All of the Bushnell manuals are located on this web site about 1/2 way down the page. Find your telescope and download a manual.
Where can i buy new Bushnell Voyager 78-9675 eye
Many on line retailers sell eyepieces. They come in three sizes, .965, 1.25, and 2 inch.
Measure the hole in the focuser. The .965 inch size is harder to find.
Here are two retailers who sell eyepieces:
http://www.agenaastro.com/
http://shop.telescope-warehouse.com/
The finderscope for the Bushnel
Obviously the mounting for the finderscope is NOT parallel with the tube-- probably the screw holes were not drilled correctly.
This is one of the reasons why we never recommend Tasco or Bushnell telescopes. They are considered "toy" telescopes and most of them are not suitable for Astronomy.
Return it and buy one of these:
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
OR re-drill the holes so the finder scope is more parallel with the main tube.
