20 Most Recent Viper RCVGC022 Remote Control Questions & Answers
0answers
2answers
Viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
4/4/2012 12:48:13 PM • Viper RCVGC022... • Answered on Apr 04, 2012
I have a 94 grand prix with a dei remote start not
It sounds like there's no power going to the starter wire. Try and locate the brain under the dash for the remote start. It should be black and about twice the size of a deck of cards with a few harnesses hanging out of it. Usually it is zip-tied to a wire harness or bracket to keep it secure and from falling down onto your feet. There should be several wires much larger than the others, and you should see fuseholders on the 2 red ones. Usually one of the fuses is used solely for the starter. Check both fuses on these larger wires. Should be 30 amp green ones if I remember right. Also, while you have the brain accessible, write down the model number on the brain itself to help you in the future. Most DEI remotes can be used for almost any DEI/Viper/Your Valet system, so it's really hard to tell what you have just by looking at the remote. If the fuses are fine, you may need to take it to a shop (anyone that sells Viper and such). If you have a chip in your ignition key, it may also be the security bypass module that gets installed with the remote start. You will only have this bypass module if you have the little chip in your ignition key. Hope this helps, good luck.
Chad
12/8/2010 5:21:37 PM • Viper RCVGC022... • Answered on Dec 08, 2010
I can not start the
check first your remote control if it is sending a command once you press a button, use the camera of your cellphone to check whether the infra red light is emitting a signal once a button is press .to do it
open the camera and aim it on the remote sensor press a button and you should see the sensor is lit.if not then you need to open the cover of your remote and try to resolder the terminal of the sensor.try to clean also the remote reciever of the viper..let me know if this work...or post a comment if you need further assistance.
11/5/2010 9:41:03 PM • Viper RCVGC022... • Answered on Nov 05, 2010
Have two remote both are working intermittently
the fact that you have to get closer sounds like the batteries are getting low
1/5/2010 4:42:57 PM • Viper RCVGC022... • Answered on Jan 05, 2010
2answers
Viper remote starter-
we have a viper 600hf and it has recently started draining thebattery and it won't stay charged.
1/4/2010 9:28:48 PM • Viper RCVGC022... • Answered on Jan 04, 2010
4answers
Viper auto alarm
Change the battery in the keyfob..
10/15/2008 2:35:06 AM • Viper RCVGC022... • Answered on Oct 15, 2008
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
7/15/2008 12:41:40 PM • Viper RCVGC022... • Answered on Jul 15, 2008
Directed Electronics (Viper) Car Security System
First of all did you remove a connection from the battery in your car so that the system can reset?
Try that first and at the same time take the batteries out of the remotes for a minute or so and hook back up.
3/9/2008 7:56:52 PM • Viper RCVGC022... • Answered on Mar 09, 2008
2answers
Why cant I use the viper 7857V with the 7701 system? Or how would I do it
Check the difference in the remote codes.
1/18/2022 8:54:10 PM • Viper Televison... • Answered on Jan 18, 2022
4answers
7941v display dark
Would like to know this as well. Having the same issue
5/8/2019 2:02:00 AM • Viper Televison... • Answered on May 08, 2019
How can I fix my viper remote ASAP? it's acting crazy
Please provide more information in regards to your problem.
3/5/2019 12:40:38 AM • Viper Televison... • Answered on Mar 05, 2019
I have a Viper RPN
Refer that question to the manufacturer of the device.
9/8/2017 8:08:42 PM • Viper Televison... • Answered on Sep 08, 2017
Viper RCVGC022 Remote Control Logo
26 questions posted
Top Viper Televison & Video Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Viper Televison & Video
Most Popular Question
viper auto alarm stuck in valet mode
  • Televison & Video
