Common faults - 1 Theheating elementscan fail(meaning open circuit) 2 There arecut-outs (T.O.C's)thatmight need resetting 3 Thethermostats (stats)can tripout or burn out (meaning opencircuit) 4 Moderntumble dryers also have sensors andpcb's (Printed circuitboards)thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is. 5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
maybe the concrete balancing weight has come loose and the fact that most of the water has been drained off when you turn it off for 10 seconds it does not have the one-sided affect anymore also check the damping springs as one may have come off in the violent spin eric
sounds like possibly a sloppy bearing causing the drum to wobble excessively nothing can be done to avoid this other than change the bearing. always assuming your load isn't seriously out of balance of course.
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing. Any idea what's going on there pls.
Hi Margaret
I'm having trouble finding the model or brand numberrs you've provided. If you look here
http://www.appliancepartspros.com/ge-washer-handle.html
you can see a selection of GE washer handles and their part numbers.It's selected for General Electric for vendor since GE manufactures
Hotpoint
Good Luck!
D
Washing machine working fine conditioner being used but water always left in draw washing machine is cold fill only
This video will show you how to keep your soap draw clear
and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
