20 Most Recent Sony Handycam DCR-PC100 Mini DV Digital Camcorder Questions & Answers
Red ligh blinking on my pc-100 memory stick
Hi try to replace the memory stick coz after it has been sitting for so long it might have burnt out. Try useing the memory stick in pc to se if it will work?
2/13/2014 8:14:13 AM • Sony Handycam... • Answered on Feb 13, 2014
I have a sony pc 100 dv cam.
your camcorder doesnt support usb connection.although it came with a pc serial cable,its the cable used for memory stick picture transfer, along with it comes a serial port adaptor for the memory stick and ac adaptor for serial adaptor. of course even if you lost this accessories you can still transfer pics from the ms using a memory card reader which works basically the same way. for videos on the tape you would just need a firewire or an ilink (ieee1394) cable. almost all mac computers support this connection.it's the dv in/out jack on the camcorder with an i symbol.upper most jack on the camcorder jack's location.check your mac to find out what cable you need.the unit uses a 4pin ilink port so you need a 4pin ilink cable at one end and the other end should match of course, the firewire port on your mac computer.should be a plug and play connection.you can use imovie software for video capturing.hope this helps.thanks :)
10/18/2013 11:42:28 PM • Sony Handycam... • Answered on Oct 18, 2013
0answers
Can you view HDV tapes
NO.
Mini DV cameras do not have the ability to read the HDV codec.
Al
2/7/2011 10:52:19 PM • Sony Handycam... • Answered on Feb 07, 2011
SONY DCR-PC100 The video control panel should
The camera has in fact 2 leds built-in, so it rather looks like one led is out, I had same problem, and sad to say stripping it down to put a new led in is,,, shall we say an eye opener, o yes a wallet opener too.
6/12/2010 3:26:52 PM • Sony Handycam... • Answered on Jun 12, 2010
Using Windows 7 virtual machine (via Parallels
Windows 7 sucks. Try "downgrading" to Win XP. I've had many problems with my new computer which had Windows 7, which have all been solved after I made the downgrading.
2/8/2010 1:41:23 AM • Sony Handycam... • Answered on Feb 08, 2010
I need a USB cable 4-pin Mini I-Link
Check your computer user’s manual, if your computer doesn’t have a Firewire port, you need to buy an IEEE1394 card to install in your computer and a firewire cable to connect your Mini DV. Check with your local computer store
6/4/2009 1:10:32 PM • Sony Handycam... • Answered on Jun 04, 2009
Mini DVD tape will not eject.
i read in the manual that if a tape gets stuck to take off the battery and connect the AC line. surprisingly it worked.
4/6/2009 11:32:54 AM • Sony Handycam... • Answered on Apr 06, 2009
How to disable auto shut off on sony dcr pc100
These people may be able to help you -
http://www.darntoothysam.com/
3/31/2009 10:18:01 PM • Sony Handycam... • Answered on Mar 31, 2009
Transferring video from tape to PC
Hi. I do know how to do that. You need some software that's capable of controlling the camera such as Adobe Premiere, Final Cut, or something like that. I believe Microsoft Movie Maker will do it and so will Roxio Media Creator which is the package they sell that burns CDs and DVDs as well. It's a whole media center.
The camera has the capability of being controlled through the firewire port on the front. You get a cable for the firewire port on the camera (firewire mini 4 pin) that goes to the computer (firewire 4 pin standard size). If you have an older computer with no firewire and it does have a PCMCIA card slot sometimes called a PC slot, or express card slot ... you can buy cards that will give it firewire ports.
You MUST have firewire to do this. The newer machines like the Acer Aspire One or any of the netbooks don't have any way to add firewire although the CPU is fast enough for video work. I capture on my old computer with firewire, and save the video to an external hard drive and edit on the netbook. Anyhow, I'm getting sidetracked!
Open your editing program and have it do a movie capture. The capture window will have buttons that look like the ones on the camera for fast forward, reverse, play, stop, etc. plus a couple for single frame reverse and forward which is useful for editing. It will also have a record button on the software. Play the tape and just as you start it, hit record. It should capture and you'll see a little data window on some software showing the frames captured and dropped during capture. That's about all there is to it. Editing is a bit trickier and I'm still learning alot of it. You can get older copies of Premiere online from a number of different sites. It's my personal favorite. It does more ... but the movie making software Microsoft provides with Windows XP and above will perform the capture perfectly well. Good luck with it.
If you have trouble, I'll be happy to get online in a chat session and talk you through it if that would help. I'm on AOL and my email is [email protected].
Lynn in New Orleans
2/24/2009 12:54:00 AM • Sony Handycam... • Answered on Feb 24, 2009
Sony DCR-PC100 does not eject (well not really!)
Don't think this is a complete solution, but it might help. Try checking out the buttons on the camera. I've got one of those same cameras but my problem is the ribbon cable in the cassette carrier broke and I'm on the hunt for a new one, and a service manual. By the way, how about emailing a copy of the service manual to me at [email protected]. Thanks. I might be able to help further with a copy of that.
2/24/2009 12:43:26 AM • Sony Handycam... • Answered on Feb 24, 2009
Opening the tape compartment
I have the same issue. The Handycam can sit on a table without anyone touching it and it acts like it is haunted. The tape sounds like it moves on its own and sometimes it won't let me playback or record. I repair shop I called told me it sounds like a $7 switch is broken, but it will cost $150 in labor to repair the switch.
11/18/2008 10:55:04 PM • Sony Handycam... • Answered on Nov 18, 2008
Problem loading tape
the tape may be the wrong sort for you particular camera or there could be falty wiring in the display box i suggest that you get a specialist to help this isn't really my cup of tea.
6/30/2008 7:17:35 AM • Sony Handycam... • Answered on Jun 30, 2008
Color balance of video output
an estimate of repair is pointless it would cost less just to get a new camera.
6/26/2008 3:01:17 PM • Sony Handycam... • Answered on Jun 26, 2008
Sony Handycam DCR-PC100 Mini DV Digital Camcorder Logo
31 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
sony pc 100 dv cam
  • Video Cameras
