20 Most Recent
Hotpoint HSS25GFP Side by Side Refrigerator Questions & Answers
No water from despener
Most times the problem is caused by the dual water control valve that controls the water dispenser. Other things could be frozen water inside the water filter assembly, lines or dispenser. Also problems with the dispenser controls=>
WR55X10446 Location number 93 =>
HSS25GFPAWW Freezer Door and Dispenser
WR57X10051 Water Control Valve
Here is a=>
Service Manual Please remember that the service manual covers all models related to yours and some parts in manual will not be related to yours.If you would like to test the water control valve carefully apply 110 VAC to the water dispenser side or check the coil with an OHM meter. I will be here to answer your questions if you need more answers but at this moment I feel the problem is the dual
water control valve , Thanks,
Sea Breeze
5/29/2023 5:14:23 PM •
Hotpoint...
Answered
on May 29, 2023
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
11/23/2022 7:49:28 PM •
Hotpoint...
Answered
on Nov 23, 2022
Control board clicks every 3 sec. No cooling. No fan or compressor running.
Avanb, I can almost assure you that the control board is the problem. I'm assuming that the interior lights are on, but no fans and the compressor is not running. To make sure, first unplug the temperature control harness. (encoder). If the refrigerator starts running, replace the temperature control board (encoder board. If it doesn't start running, replace the main board in back. To remove the control panel, remove the 2 screws located on the bottom. Slide the panel down. Then just disconnect the harness to the temperature control. Catriver.
8/7/2019 5:05:16 PM •
Hotpoint...
Answered
on Aug 07, 2019
I have a Hotpoint HSS25GFTA WW Fridge that has
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
7/10/2017 5:53:14 PM •
Hotpoint...
Answered
on Jul 10, 2017
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
3/3/2017 5:37:21 PM •
Hotpoint...
Answered
on Mar 03, 2017
The water dispenser stopped dispensing.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in the door is frozen , GE has a dispensor heater which comes with instructions to install . Pt # WR49X10173 .
12/19/2015 9:13:39 PM •
Hotpoint...
Answered
on Dec 19, 2015
My fridge knocks when running
Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an 8-10 hours is more than enough time some say less.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
4/21/2015 7:31:19 PM •
Hotpoint...
Answered
on Apr 21, 2015
