20 Most Recent
Videoseven V7 L19PS 19" LCD Monitor Questions & Answers
There is a yellow question
if your computer came with a motherboard disk the driver could be on it
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
hope this helps
When switching on the monitor v7 it makes a
sales669, You or a qualified electronics technician will need to open unit for inspection and repair. Do not use unit if you smell ozone and continue to hear noise!!!! Any one or a combination of things can be causing your symptom. Do you have any possibility of doing warranty service, or is unit to old? In fact if it were me, I would disconnect it and use a spare unit until v7 lcd is repaired. Read more of my fixya profile to see if something fits your BLACK SCREEN problem. I would guess that your power supply inside of monitor needs some work done! 12fixlouie
White screen only
The white screen indicates wither a blown power supply or a blown fuse on the LCD panel. If the monitor is in warranty contact your place of purchase. If it is not in warranty then we should be able to repair it for you. Our repair charge is $30 plus return shipping. Contact us at the email address below if you need any more information.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Cannot change to digital from analogue
Make sure you are using the proper connections.
VGA is analog and DVI is digital.
If you are using DVI and still having the same problem, then it may be a graphics card signal issue.
Dead Monitor
check the plug at the back of the monitor. insert it properly
The color is blue
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
Screen goes blank
Hi jkm007,
Sounds like the back light inverter board is bad.
It's a very common problem.
LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it)
The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display.
If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad.
The inverter board and CCFL's are replaceable.
Good Luck,
El Duderino
