Hi
Intake/Drain light flashing means an issue while
draining. You would need to check for air gap on the dishwasher, it may be
clogged. It prevents dishwasher from draining, sometimes the drain flow is
restricted due to gunk. Cleaning or bypassing the air gap will resolve the
issue. If this doesn't resolve the issue then it is due to seized (or stuck)
drain pump. Disconnect the power to the dishwasher or turn off the breaker to
the dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections &
remove motor (single screw holds motor, it is on the outside back of the
machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate
it, then motor will be required. If the error still appears then cancel the
error message, turn the rotary selector switch to "Stop/End" or press
the "Start/Stop" switch for approx. 5 secs. Switch the appliance off
and then back on again. Hope this helps... Please post back if you need more
information.
Daniel
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
64 questions posted
118 Questions
95 Questions
90 Questions
67 Questions
58 Questions
