20 Most Recent
Casio Fx-992s Scientific Calculator Questions & Answers
How to make my degree button work?
I am sorry but the image does not show any Degree button.
To set the angle unit you have to press the Mode button twice before you arrive at the angle unit configuration. See the screen capture below.
How do i make the degree button of my fx992s work?
How and key to inverse
Look for a key marked [x^-1] or [1/x]. The marking may be on the key or on the face of the calculator. In the latter case you will have to press the SHIFT key first. Before you can calculate the reciprocal of a number the number must be entered.
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
Casio QT-6600 kitchen printer stop working.
Is there lights on, on the printer? Does it have a receipt paper roll in it?
You can do a Power Cycle of the Terminal and the Printer. Unplug the printer for the wall socket. Remove the data socket, replace the data socket making sure the connection is tight.
Disconnect the terminal from the main power, and count to 20. Plug the terminal back in.
Now go to the kitchen and plug the printer back into the mains.
The reset should fix it. The rest is in the manual, which I told you earlier today. Yes it is complicated and you may have a network switch if you have multiple terminals and possibly a computer joining everything. If you find that too complicated, call the company that sold you the unit and tell them to bring a new ticket printer with them 'just in case'. That type if ticket printer is fairly specialized, but they are common. They normally don't charge for that type of help
In the manual under Remote Printer Control.
https://totalpos.co.nz/wp-content/uploads/2020/03/QT6600-Reference-Manual.pdf
More here
https://www.google.com/search?q=Casio+QT-6600+connect+kitchen+printer
