20 Most Recent Miele Touchtronic W1213 Front Load Washer Questions & Answers
W1213 Touchtronics intake and drain light is blinking
Foam has probably got into the logic board, and a new board is probably needed. Sorry !
2/2/2018 7:23:25 PM • Miele... • Answered on Feb 02, 2018
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside. Fixed it by: Cleaning drain. Unplugging from power. Tilting forward to drain water for 1-2 mins. Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load. Plugged power back in. Boom, she started up. This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above. HTH
4/8/2016 3:49:26 PM • Miele... • Answered on Apr 08, 2016
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal, In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
9/26/2015 10:04:27 AM • Miele... • Answered on Sep 26, 2015
Miele kfn8562sd display are showing correct temp.Fridge & Freezer warming up.No noises coming from the unit,humming or gurgling.
Check the start up relay is clicking when you first turn it on , then check thermostat.
11/15/2014 9:35:45 PM • Miele... • Answered on Nov 15, 2014
0answers
Miele clothes washer buzzer comes on with three dashes on screen, won't start
check the dustbuster
5/27/2014 7:10:29 PM • Miele... • Answered on May 27, 2014
0answers
Wont turn on
Be the first to answer 3/18/2014 4:49:48 AM • Miele... • Posted on Mar 18, 2014Be the first to answer
0answers
Out of balance
Be the first to answer 2/19/2014 4:28:11 AM • Miele... • Posted on Feb 19, 2014Be the first to answer
0answers
0answers
I live in Venezuela and I need to know a serial spare part
go on line to miele spare parts and they can help you
1/25/2014 6:06:21 PM • Miele... • Answered on Jan 25, 2014
Miele Touchtronic W1213 Front Load Washer Logo
85 questions posted
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Miele Washing Machines
Most Popular Question
live in venezuela need know serial spare
  • Washing Machines
