20 Most Recent
Sharp ER-A320 Cash Register Questions & Answers
Tax function not working
After programming the tax you also have to link the taxable PLUs or department to tax by using the digit one and 0 for the non taxable
All my register will is beep
If the beep is happening every second or so with out you touching it, the printer has a fault. If it happens when you press buttons, try this: If you press clear (CL) and press some of the numeric buttons, you should see numbers appear on the display. If not, probably a keyboard fault. If you can get numbers but just a beep when you press a department (item button) then you are not logged in. Enter your secret PIN number and press the CASH# (cashier number) button in the top corner (on most models in this series) to log on. If you need to program new secret PIN numbers, one of the users has the programming manual here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp7.php
Why is there a horrible grinding sound coming from the ink roller area?
159.203.8.28/.../how-can-i-make-my-sharp-xe-a102-
cash-
register-work
package of three sharp xe a107 cash register ink roller ... on in a few min. the car dies ยท Why is there grinding noise on driver's side as wheel is in motion? ... I have 05 honda pilot with a bad transmission what other type of transmission would fit ...
