20 Most Recent HP DesignJet 450c InkJet Printer Questions & Answers
7answers
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
7/30/2021 7:04:55 AM • HP DesignJet... • Answered on Jul 30, 2021
DESIGNJET 450C SMEARS (BLEEDS) INK
Most likely the media (paper) is touching the print heads. This can occur because 1) the media holding mechanism is not holding the media correctly, and the media buckles, or 2) the carriage to media distance is too small. (Check the adjustment in chapter 5 of the manual). I found a copy of the procesure online: HP DesignJet 430 Service Manual Adjusting The Carriage To Media Distance
12/27/2017 4:11:38 AM • HP DesignJet... • Answered on Dec 27, 2017
Connecting the JetDirect 300x to my HP Designjet 450c
If you have a tower, rather get an internal parallel card.... works like a dream
7/5/2016 1:01:36 PM • HP DesignJet... • Answered on Jul 05, 2016
2answers
Download driver
6/2/2016 10:53:14 PM • HP DesignJet... • Answered on Jun 02, 2016
HP Designjet 450c 36" Printer
go to www.hp.com and download the related driver for visa. it work thanks
3/17/2014 1:06:50 PM • HP DesignJet... • Answered on Mar 17, 2014
I have hp designjet 450c..the problem in printing.while printing it prints copy of the image also and not clear.i dnt know whts the problem..please help me..
That usually is caused by clogged or damaged printheads. There are 4 printheads, Black, Cyan, Magenta and Yellow. When you replace the printheads you need to calibrate the machine so the colors line up with one another.
3/16/2014 1:47:34 AM • HP DesignJet... • Answered on Mar 16, 2014
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a b
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
3/2/2014 12:03:26 AM • HP DesignJet... • Answered on Mar 02, 2014
0answers
2answers
DRIVER PROBLEM FOR HP DESIGNJET 450C
First try the driver for XP
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=12686&prodTypeId=18972&prodSeriesId=25253&swLang=8&taskId=135&swEnvOID=228
If that does not work try the driver for the designjet 500 or 430 sometimes a like model driver will work.
12/1/2013 10:38:22 AM • HP DesignJet... • Answered on Dec 01, 2013
Hp design jet 500 prints a color test and small
More than likely one or more of your color printheads are worn out and need replaced...they are around $40 - $50 each and are relatively easy to replace.
10/16/2013 6:08:34 AM • HP DesignJet... • Answered on Oct 16, 2013
Prints to close to the end of the paper
I need more detail about your printer's issueanyway if you mean while the printing it close " switching off " mean you have issue with power supply , if you mean just stop printing but still on that means maybe with Memory , I hope help you Mohamed Hejazi Afaqnama Libya [email protected]
3/21/2013 6:41:04 PM • HP DesignJet... • Answered on Mar 21, 2013
How do i load the paper for printing
Follow the manual... or else see the link http://www.youtube.com/watch?v=2CSAN6p4lAU
2/13/2013 9:47:57 PM • HP DesignJet... • Answered on Feb 13, 2013
My designjet hp 430 is
Coverage and nothing else. Are the cartridges new or refilled .....
8/30/2011 3:45:54 PM • HP DesignJet... • Answered on Aug 30, 2011
HP DesignJet 450c InkJet Printer Logo
153 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
hp designjet 450c driver windows vista
  • Office Equipment & Supplies
