20 Most Recent
HP LaserJet 4100 Printer Questions & Answers
HP 4100 printer SHOWING 'cold reset'
FIRST Turn the printer on.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button. ...
Release the (Select) button.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button until control panel displays COLD RESET.
Press (Select).
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
My printer shows 41.2 errors
Hope it helps
1. A temporary printing error has occurred.
2. Press GO. The page containing the error will automatically be reprinted.
3. Reseat the connections to the laser scanner and then to the engine controller board.
4. Replace the laser scanner.
5. Replace the engine controller board.
