20 Most Recent
HP PSC 2210xi All-In-One InkJet Printer Questions & Answers
Printer won't print; says scanner only after
Follow these steps to resolve your problem..
Solution #1 Power cycle both devices (Printer & Computer)
- Turn off your printer.
- Unplug the power chord at the back of your printer.
- Completely shutdown your computer.
- Unplug / disconnect the USB cable at both ends (printer & computer)
- Wait for at least 1min.
- Plug the power cable back in to the printer make sure that the other end of the power cable is connected directly to the wall outlet.
- Turn on the printer.
- Check if you can make a copy, if yes proceed to the next step.
If not, and you are still hearing some unusual sounds on the printer go to the last step.
Solution # 2 Check if you can now print using your computer
- Plug the USB cable back in to the both ends (printer & computer)
- Download the Print diagnostic utility (click on Download below to download the tool)
- It will ask you to run or save it. (save it, so that you can use it on the next time that your having problem with printing issues)
- Run the software.
- Highlight your printer by clicking on it.
- Click on Diagnose.
- If you have to the FIX button available, click on it.
- After fixing the issues, restart button will appear. click on it.
- Check if you can now print.
DOWNLOAD (
print diagnostic utility)
Solution #3 Call HP and have your printer trade in (
last step)
Call HP @ 1-800-474-6836, If the printer is no longer covered by the warranty charges may apply.
Will not scan???
You need to check if the printer is properly connected to your pc and that the scanner driver was properly installed.
Connect the printer to a pc.
Assuming you are using windows operating system, go to control panel and double click the Scanners and Cameras icon. If you find the image of your printer then scanner driver was installed and that it is ready for use. If there is no printer in there, then the scanner driver was not installed and will need to run the cd installer that comes with your printer and install the driver for the scanner.
If by pressing the scan button on your printer and did not work, I do suggest you use the scan option on the control panel.
Let me know if I can help you further.
I have an HP PSC 2210xi All-in-One Printer on a
Sadly to say you wont be able to install it without windows 7 update. You may call HP and request the CD sent to you but i doubt they will help you. They will actually charge you for the cd. Thats one of the reasons i dont buy HP. Go with Brothers all-in-one printer. They sell it for 79.99 at bestbuy
Will not copy - error reads that paper is too
Make sure the little tabs on the printer tray that sense paper, size etc. are free to move, make sure they don't have any small pieces of paper or crud in them, also try unplugging your power cord for a few minutes then plug it back in and power the printer up.
HP 1310 series
I have an HP PSC1315 which is virtually the same printer. I actually created my own template where 10 business cards are printed as if it were one sheet of paper(like a poster). Of course you you can't select how many cards print, or which card to start on, but at least I get 10 perfectly centered cards.
All in One psc2210xi printer
Hello, the electrical spike may have also affected your pnter's USB port or worse. Does it copy/scan/fax ok? Try using the one of the USB ports from the back of your computer. USB printers do not like low speed, low power USB ports. Are you using a USB hub or plugging it into a usb port on your keyboard? I doubt the cable is bad, but check it carefully for any black marks on both ends. Have you tried other USB devices on this newly rebuilt computer?
Good Luck!
Faxing and receiving faxes
Hi, are you using the phone cord that came with your printer? If so, try a different cord if you have one. Can you plug a regular phone into that wall jack - does that work (dial-tone)? Are you using VOIP (like Comcast triple play), DLS or regular analog telephone service? If VOIP you may need to slow down your fax machine settings. Let me know how you make out.
Hp psc 2210 all in one
You can download the drivers from HP's site
here. You can also order a replacement for the cost of shipping from a link from this page.
If you are using Windows 98 or ME the drivers are no longer available from HP. In this case please post a comment here with your OS and we can try to find you a solution.
Regards,
Bob Headrick, MS MVP Printing/Imaging
