20 Most Recent
HP LaserJet 2430 Printer Questions & Answers
I have a hp 2430 paper jam 13.20.00 and can't find
If the paper jam error first occurs just after you have replaced the toner cartridge (as it did for me), carefully look inside (with toner cartridge removed) near the rear at the fuser and there may be a black piece of paper sticking out and/or curled up against the back. I needed a flashlight to see it but still wasn't sure until I felt around and found it. It was the protective sleeve that was around the drum in the toner and when I replaced the toner I missed it. When I first powered up the printer, the sleeve got fed partially into the fuser and the tail curled up against the back, making it practically invisible. Also, with that jam, the printer made no motor or gear train noise at power on so it almost had me convinced that the motor was bad. After removing the black piece of paper, the printer initialized normally.
How do I scan a document in pdf format ?
The process is changed during SAVE AS function. You can set to save into a folder, and in which format (.jpg, .pdf, etc.).Use the desktop application, tons easier than the printer interface.
HOW DO I REMOVE TRAY2?
Tray 2 should be the one on the bottom and you should be able to put your fingers under the middle section and pull it out.
How do you check the
Using the HP Toolbox
HP Toolbox is a Web application that you can use for the following tasks:
? Check the printer status.
? Configure the printer settings.
? View troubleshooting information.
? View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when it is connected to the network. You must perform a complete software installation in
order to use the HP Toolbox.
Dim printing
Depends how much you are using it. Typically the printer will warn you when it is low. Also you can print a supplies page from the printer menu to see how much toner you have left.
How to change paper trays
Press menu button, scroll to tray behavior, in that select type of paper, default tray & paper size etc..
