20 Most Recent HP DesignJet 1050c InkJet Printer Questions & Answers
2answers
Push power button on front panel and print head carriage zooms behind ink station and crashes.....
Manually try to pull out service station(where print head cleaners located)., feeling very hard?.. cleaning and lubrication required.. Remove right cover., cheat the door sensor., switch on the printer & check for the where is the abstraction?.. If found any paper particles, remove & try.. Still problem persists, service station required over haul & lubrication.. But only professionals can perform this activity., .. Note: Don't switch on the printer without print heads..Once printer treats no print heads in carriage, it will ask for health print heads for alignment., result you need to spend for full set of print heads.. be care full..
6/7/2016 9:42:08 PM • HP DesignJet... • Answered on Jun 07, 2016
0answers
2answers
Check Printhead cleaner Path
Sounds
    1. Attempt to duplicate the message by turning the printer on, reloading the media, and printing several test prints.
    2. Note the movement and position of the carriage when the error occurs.
    3. If the carriage stops on the left-hand side (roughly 12 inches from the ink supply station), unplug the power cable from the printer, open the top cover and try to move the carriage to the right. Closely inspect the ink tubes for wear, and check for ink tube binding or catching on the tube guide (stopping/hindering carriage movement). If true, continue with the remaining steps below.
        NOTE: If the steps above do not describe the issue correctly, refer to the work instruction for a typical “Switch Power Off, Check Printhead Path” message (bpp90070).
Check/replace the Ink Tube Systemgtabtop.gif
    1. Turn the printer off.
    2. Remove the old Ink Tube System (refer to pages 8-53 of the Service Manual).
        NOTE: If the printer is installed on a Multi-roll feeder accessory, some additional disassembly is required to gain access to the printer. Instructions for multi-roll disassembly are listed at the bottom of this document for reference.
    3. Move the carriage assembly to the right side of the printer.
    4. Clean the rear tube guide assembly with a moistened lint free cloth to prepare the mounting of the Mylar tape.
      Figure 1:Cleaning the rear tube guide assembly
    5. Remove the backing on the Mylar tape and align the line on the tape with the front edge of the rear-tube guide so that the narrower section is towards the front of the printer. Do not attach the tape yet.
      Figure 2:Aligning line on Mylar tape with front edge of rear-tube guide assembly
        NOTE: Ensure that the Mylar film is perfectly aligned with the rear Tube Guide surface with no protrusions or unevenness.
    6. Carefully position the Mylar tape about 1/4 of an inch from the left-end of the rear-tube guide (do not go all the way to the end as the beveled edge will cause crimping of the tape).
      Figure 3:Attaching the Mylar tape
    7. Ensure tape is evenly positioned and any air bubbles are smoothed out along the tape.
      Figure 4:Smoothing out the air bubbles along the Mylar tape (view from rear of printer)
    8. Carefully fold under the narrow section of the tape to the underside of the rear tube guide assembly and smooth out any air bubbles.
      Figure 5:Installing Mylar tape under rear-tube guide assembly (view from front of printer)
    9. The Mylar tape should look like the image below.
      Figure 6:Final installation of Mylar tape (view from top of printer)
    10. Once the Mylar tape is installed, install the new Ink Tube System (refer to pages 8-53 of the Service Manual).
    11. Following replacement, verify printer functionality.
like a bad belt.
4/23/2014 1:34:13 AM • HP DesignJet... • Answered on Apr 23, 2014
Ink tube reset
Look the attachment.. ae232dc4-e784-499e-8c54-6e55e8929693.gif Hope It's resolve all Your Printer Problem, Or Still having Problem Then follow Us For HP Support
4/22/2014 8:32:43 PM • HP DesignJet... • Answered on Apr 22, 2014
How do I replace the Cartridge
Gently push then up & pull out the desired cartridge, insert new one in the same manner .
4/9/2014 12:39:50 PM • HP DesignJet... • Answered on Apr 09, 2014
0answers
0answers
1050c DESIGNJET REPLACE MAGENTA ISSUE
one of the first signs of a faulty power supply is a washed out display, also you may hear a slight buzzing noise, you may need to replace the ISS Pwb ( part of the tubes ) not order able separately, it has been known that the connector block ( for ink Cart) does fail, I would try swapping it with another colours and see if the fault follws the connector block, it may just be a bad chip on the ink cart.
2/19/2014 12:49:16 PM • HP DesignJet... • Answered on Feb 19, 2014
0answers
System error hpdesignjet 1050c error 09B300
09Bxx0 errors relate to hdd read fail,# there are two causes for this -1) the Hdd has indeed failed 2) the power supply in particular the hdd power supply(part of the main PSU) has failed- easiest way to see is connect a diferent hdd to the machine and see if it spins up if it does replace the hdd if it does not then replace the psu
2/12/2014 10:35:49 AM • HP DesignJet... • Answered on Feb 12, 2014
Error code 09A008 007A07B2
this is a HDD faillure waring- this may be down to the hard drive or it has been known for the power supply to cause this error also, start fist with the hdd replacement , as its the cheapest option, it has to be a HDD that matches your exact model type eg 1055cm+ PS3 will not work in a 1050c (hp/gl)
2/12/2014 10:14:51 AM • HP DesignJet... • Answered on Feb 12, 2014
HP DesignJet 1050c InkJet Printer Logo
181 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
hp 1050 non genuine cartridge
  • Office Equipment & Supplies
