20 Most Recent Daewoo Baumatic Fridge Freezer Fan Motor 3015915900 Questions & Answers
2answers
The deodoriser & fuzzy lights are alarming & sometimes the light goes out. the fridge door doesn't seem to be closing properly?
need more info Model # door not closing will cause all kind of problems
9/5/2023 7:49:48 PM • Daewoo Baumatic... • Answered on Sep 05, 2023
I have a Daewoo FRS 2031IAL that is leaking at the
http://www.partmaster.co.uk/search.pl?query=FRS+2031IAL
5/24/2019 6:30:24 PM • Daewoo Freezers • Answered on May 24, 2019
Daewoo FRSU20DCB not making ice
Sounds like you have an airflow issue. Freezer temp. should be @10-15 below and fresh food area @35-37 above zero You may have an evaporator fan or door switch failure . https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help This link can help you diagnose your problem. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 10:56:41 AM • Daewoo Freezers • Answered on Dec 31, 2017
Changing water filter cartridge
turn water off
3/2/2017 7:15:04 PM • Daewoo Freezers • Answered on Mar 02, 2017
Model No.ERF415M 13CT. I have
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
3/2/2017 7:03:51 PM • Daewoo Freezers • Answered on Mar 02, 2017
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
7/12/2016 3:52:56 PM • Daewoo Freezers • Answered on Jul 12, 2016
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
7/22/2014 2:55:52 PM • Daewoo Freezers • Answered on Jul 22, 2014
My daewoo FRSU20DCB has appeared to stop making
i have the same problem and have tried to contact daewoo on a number of occasions but only to be passed onto an engineer who wants to charge me min two hundred pounds
6/10/2014 6:01:05 PM • Daewoo Freezers • Answered on Jun 10, 2014
0answers
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
4/29/2012 3:10:52 PM • Daewoo Freezers • Answered on Apr 29, 2012
I have a Daewoo FRN U20DA type american fridge
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
2/27/2011 7:50:40 PM • Daewoo Freezers • Answered on Feb 27, 2011
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Daewoo Baumatic Fridge Freezer Fan Motor 3015915900 Logo
5 questions posted
Top Daewoo Freezers Experts
ADMIN Andrew
ADMIN Andrew
Ismail Soomro
Ismail Soomro
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
View Most Popular
Daewoo Freezers
  • Daewoo Freezers
Most Popular Question
deodoriser amp fuzzy lights alarming
  • Freezers
