20 Most Recent HP DeskJet 6840 InkJet Printer Questions & Answers
Thanks for sending me the user manual; I
You need to print out a report from the printer on what its URL name is to be able to type it in your safari browser and look up and change the internet settings on page 23 of http://h10032.www1.hp.com/ctg/Manual/c00256077 There will be a setup program in the downloaded software or a driver setup program . Once you change the ip address of the printer to match your mac ip range and subnet mask you may find your apple IMAC may detect your printer and set it up automatically You have to download the mac version of the driver on the MAC as Apple has a different file system to windows. http://www.hpdriver.net/goto/http://ftp.hp.com/pub/softlib/software9/COL21675/mp-56790-1/HP_Installer_DJ6800_DJ6600_v9.7.dmg note the dmg file extension not straight forward read the forum posting below on how to open a dmg file and copy and run the contents https://apple.stackexchange.com/questions/64845/how-do-i-install-applications-from-a-dmg-file
4/15/2017 12:18:06 PM • HP DeskJet 6840... • Answered on Apr 15, 2017
2answers
Connected HP6840 to iMac with
Hi there.
Actually you can. You can make it wireless if you have a wireless router.
Click this link for the manual on how to.
Hope it serves you well.
Thank you!
4/15/2017 12:08:47 PM • HP DeskJet 6840... • Answered on Apr 15, 2017
2answers
Laptop wont connect to printer
Try to re install driver and make it your defauld printer. Check your wireless conection.
9/11/2016 2:22:27 PM • HP DeskJet 6840... • Answered on Sep 11, 2016
Door open error on HP6840 printer when door is closed
Here's the answer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065334&cc=us&lc=en&dlc=en&product=385458
The sensor is probably stuck, and it took me a few minutes to fix!!
Good luck...
Peter
5/15/2015 2:29:56 AM • HP DeskJet 6840... • Answered on May 15, 2015
2answers
Printer lost static IP address with new router and won't install on network.
Your printer is looking for your old router. Reset the printer:
  • Verify that the printer is powered on.
  • Press and hold down the Report Page button.
  • While holding down the Report Page button, press the Cancel button three times.
  • Release the Report Page button.
Now, re-connect your printer to you new router. Source : Re Can Get DeskJet 6840 To Work on Wireless Network Need HP Support...
4/13/2014 2:54:19 PM • HP DeskJet 6840... • Answered on Apr 13, 2014
Disassemble
If you get this error: Top Cover Open. The device cannot print because the top cover is open. Close the top cover and press continue, or cancel the printing. then follow this guide: HP Support document HP Support Center
2/12/2014 5:56:08 AM • HP DeskJet 6840... • Answered on Feb 12, 2014
0answers
0answers
2answers
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid. Geezer Geek
2/5/2013 7:40:59 PM • HP DeskJet 6840... • Answered on Feb 05, 2013
Printer communicates "cover is open"
1.Power off printer
2.Open cover
3.closs cover
4.swich on printer
ok
9/24/2011 3:50:58 PM • HP DeskJet 6840... • Answered on Sep 24, 2011
Trying to connect printer to
Once you plug in the printer it should try to install driver software. If it does not do this automatically then you can use the disc that came with your printer. Once this is installed try to print with Microsoft word or any other program and make sure the correct printer is selected. Hope this helps!
6/23/2011 7:12:39 PM • HP DeskJet 6840... • Answered on Jun 23, 2011
3answers
How to check ink levels in win 7
The HP Solution Center should provide you with your ink levels.
3/3/2011 12:08:56 PM • HP DeskJet 6840... • Answered on Mar 03, 2011
0answers
HP DeskJet 6840 InkJet Printer Logo
52 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
printer lost static ip address new
  • Office Equipment & Supplies
