20 Most Recent
HP LaserJet 2550L Printer Questions & Answers
Why wont cartridges align correctly?
Now this is a good one. There are a lot of possible answers so I will just give the basic ones. The cartridges might be having problems you can check to see if they are all the same brand, the Carousel or Carousel Motor could be bad. The Formatter(controller) Board could be going bad.
Your best bet would be to get a technician to take a look at it.
Faded colors
If the color cartridges and Image transfer kit are good then you should check and clean the Laser Engine or replace the Laser Engine with new one.
Red light flashing
The red light is indication there is an error. Reset does not solve the problem. First solve the problem, like close all doors, or replace cartridges, then try to reset by switching off and unplug from the mains. Then reinsert the mains plug and switch on again.
If the red light comes back, you did not solve the problem. Read the manual, or give more details, so we can help.
V have problem in hp2550
Make sure that the power is coming directly from the wall outlet. DO NOT use a surge protector.
Power off for 30 minutes. Power back on. If error returns, replace the fuser.
