20 Most Recent
HP OfficeJet 7310 All-In-One InkJet Printer Questions & Answers
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
Error code 0x07a74dd6 and 1959:lib_barracuda.c
Unplug
Wait 20 secs
Plug it back in while holding 6 and #
Continue to hold until a reset notification pops up (this may take a while).
The error may pop up again, just unplug and plug back in and you should be good.
How do I get printer online
All of the information is in the manual. You can select one here to download:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-003&h_client=z-a-r1002-3&jumpid=hpr_r1002_usen_link1&h_lang=en&h_cc=us&h_query=+HP+OfficeJet+7310
Printer driver missing
- click here for driver(
Printer)
- click here for driver( HP officejet 7413 All-In-One
Printer)
- click here for driver(HP officejet 7410 All-In-One
Printer)
i hope this will solve your problem
regards,
cseian
Printer status reads "printer offline"
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
Full Reset:
1. Tun Power OFF
2. Wait for 10 secs
3. Turn Power ON while holding 6 and #
4. Continue to hold until a reset notification pops up (be patient).
Note: The error may display again; just unplug and plug the power cord back in and you are good to go.
Does not print in color
Check you have colour ink left in the cartridge also check the default printer properties are not set to black and white.
