20 Most Recent
HP ScanJet 2400 Flatbed Scanner Questions & Answers
UNABLE TO SAVE DOCUMENT AS
You need to install a printer driver PDF program on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file.
To download Cutepdf PDF printer driver (freeware) click onthis link :-
http://www.cutepdf.com/
I'm trying to scan an
Hi
Try the HP software rather than the Scanner itself.
HP Solution Center > Settings > Scan Settings > Scan Document Settings > make sure it is set to Scan Document as Image (no OCR) > Apply > OK.
I hope this helps.
Yes
Yes, OCR software takes a page of "printed" text, and tries to use image-processing techniques to
O(ptically) do C(haracter) R(ecognition) to extract the text, letter-by-letter, and to create a "text" document that you can "edit" on your computer.
The scan image becomes yellow
It is due to the dust accumulated in the tinted glass near the bulb. so open the glass by unscrewing the screws and clean the tube bulb and nearby mirror glass with the pure cotton and fix as same and retry. Pl give me your feedback
