20 Most Recent Maytag Centennial Top Load Washer Questions & Answers
4answers
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
12/3/2018 8:42:10 PM • Maytag... • Answered on Dec 03, 2018
Maytag cenennial washing machine begins the cycle but stops, all lights remain on but machine is not washing.
Press cancel twice and unplug for 10 minutes to reset the board
4/3/2016 9:20:09 AM • Maytag... • Answered on Apr 03, 2016
Sensor light not coming on after fill cycle
After fill it should be washing and not sensing. What is your concern or trouble you are having
4/3/2016 9:18:34 AM • Maytag... • Answered on Apr 03, 2016
If I put more then 2 pair of jeans it won't spin out. Is the censor gone or barrel off
The barrel is out of balance. Remove the jeans and redistribute evenly, or wash fewer pairs of jeans at a time.
2/2/2016 1:00:05 PM • Maytag... • Answered on Feb 02, 2016
No water will pour down to start a wash
Hi, First is the supply turned on? Do you hear a buzzing sound when starting a load? if not, it may just be the fill valve assy/ solenoid. A reasonable cost for this part is about $15-20 plus 1/2-3/4 hours labor. If so the buzz indicates the valve is attempting to open or opening and there is an obstruction in water line or supply may be off. Do any of the cycles work? If nothing works some models lock out with a lid switch. I have seen alot of failures in this model see link Maytag Legacy Washers amp Dryers I hope this answer helps in some way. Hard to diagnose when not at unit.-Mtlgod
12/15/2015 9:13:26 PM • Maytag... • Answered on Dec 15, 2015
0answers
0answers
Coninuosly repeats spin cycle, any suggestions how to remedy this? I have to manually cancel the cycle in order for the machine to stop recycling through spin
I had a Centennial washer on a service call doing this just the other day... After putting it trough diagnostics I found no errors and all the washer's mechanics tested okay. After resetting the control by putting it trough the diagnostics mode it continued to repeat cycles without restarting the washer.
  • Try running it through diagnostics and see what error codes are in the memory. (Guide is linked below)
  • What are the codes? do they give any more clues?
  • clear the codes and run a test cycle.
  • does it work?
  • if it checks out properly with the diagnostics it's probably a bad control board...
Maytag Centennial Washer Diagnostic Guide If it does turn out to be the control try contacting Maytag (Whirlpool) for a parts concession... Whirlpool customer service guide is linked below. Hope that helps! Good luck!
6/17/2015 2:16:57 PM • Maytag... • Answered on Jun 17, 2015
Does not drain completely
EITHER A BAD CLOGGED PUMP OR BAD CLUTCH ASSEMBLY? A BAD MOTOR COUPLER OR LOOSE WORN BELT DEPENDS IF ITS DIRECT OR BELT DRIVEN. not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-0.jpg not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-2.jpg not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-5.jpg not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-9.jpg not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-14.jpg not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-20.jpg not-drain-completely-y0uj30y2msg4iwsg11dgquj1-5-27.jpg
5/31/2015 9:45:43 PM • Maytag... • Answered on May 31, 2015
2answers
Washer does not drain completely how do i fix
Washer will not drain: Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement. Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed. If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good! washer-not-drain-completely-fix-cs4uo0ksqeekdm4wcgxnqiuz-3-0.jpg washer-not-drain-completely-fix-cs4uo0ksqeekdm4wcgxnqiuz-3-2.jpg washer-not-drain-completely-fix-cs4uo0ksqeekdm4wcgxnqiuz-3-5.jpg washer-not-drain-completely-fix-cs4uo0ksqeekdm4wcgxnqiuz-3-9.jpg
5/29/2015 10:50:52 PM • Maytag... • Answered on May 29, 2015
What is wrong when the washer will not add water after the sensing stage?
Refer to repairclinic.com repair self help section. Have your model number ready to enter for specifics on your machine. Good luck.
4/26/2015 5:03:53 PM • Maytag... • Answered on Apr 26, 2015
Washer agitates @ startup while filling
bad water pressure switch
3/29/2015 7:07:23 AM • Maytag... • Answered on Mar 29, 2015
My washer will not aggitate at all. What could be the prolem?
No agitation? first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. If both check ok then next CHECK the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
3/29/2015 6:58:48 AM • Maytag... • Answered on Mar 29, 2015
Maytag Centennial Top Load Washer Logo
86 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
repair manual download repair manual
  • Washing Machines
