20 Most Recent
Maytag Bravos Top Load Washer Questions & Answers
Maytag bravos x lid lock overide or bypass
Washer not starting Cycle:I would have to slam the washer lid before the washer recognized the lid was shut.What I did to fix:1. Ref the link below for Schematicshttp://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/2. Looking at the Lid Lock section of the Schematic: Place a jumper between pins 2 and 3 of J15 This engages the 1st switch (Lid switch) so, I don't have to slam the lid anymore3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.If you find that your machine is still not starting the cycle after jumpering pins 2 and 3, you will need to replace the Lid Lock mechanism or ref the above link for temp bypass.
Lid lock broken can I overide?
Washer not starting Cycle:I would have to slam the washer lid before the washer recognized the lid was shut.What I did to fix:1. Ref the link below for Schematicshttp://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/2. Looking at the Lid Lock section of the Schematic: Place a jumper between pins 2 and 3 of J15 This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.If you find that your machine is still not starting the cycle, you will need toreplace the Lid Lock mechanism or ref the above link for temp bypass.
Grinding or croaking noise in washer
What you want to do is first unplug the machine. With that done have someone tilt the machine backwards while you lay in front of it to look. You'll notice a white foam like bottom, which you want to pull out. Watch as you doing so because the next step. There is a nut that screws onto the bolt that the pulley slides on to. Its a manufacturer defect, and when I was doing first year warranty for whirlpool I'd get about three a week. My solution to it. Get the belt around the pulley, push the pullley all the way up to where its supposed to sit, get some lock-tight and place on the bolt, not too much, and put your nut back on and ratchet it tightly. I've had no recalls using this method. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
Maytag MVW7232HW0 top load, error codes and condensation on control panel when using hot watet
1. ERROR CODES: CHECK THE USER MANUAL FOR THE WASHER TO IDENTIFY THE SPECIFIC ERROR CODES BEING DISPLAYED. THIS WILL HELP YOU PINPOINT THE ISSUE AND TAKE APPROPRIATE ACTION, SUCH AS RESETING THE WASHER OR CONTACTING CUSTOMER SUPPORT.
2. CONDENSATION ON CONTROL PANEL: IF YOU'RE EXPERIENCING CONDENSATION ON THE CONTROL PANEL, IT COULD BE DUE TO THE HOT WATER TEMPERATURE OR THE HUMIDITY LEVEL IN THE ROOM. TRY USING WARM WATER INSTEAD OF HOT WATER TO SEE IF THAT REDUCES THE CONDENSATION. YOU CAN ALSO TRY INCREASING VENTILATION IN THE ROOM TO HELP DISPERSE THE MOISTURE.
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
