20 Most Recent Roper RAS6233KQ Top Load Washer Questions & Answers
We have a Roper 7
most likely needs new lid switch assy.
5/8/2017 12:43:07 PM • Roper RAS6233KQ... • Answered on May 08, 2017
Washer won't start/fill/spin -- anything
Dea, does the washer fill? If it fills and justs sits there it could be the pressure switch. If it fills, agitates and then no spin no drain, then it's the lid switch. If it doesn't do any of the above, it may be a timer issue. Lift the lid and gently lower it, do you hear a click when the actuator on the lid hits the switch? I will attempt to attach a picture on how the consol flips up to see the lid switch harness, pressure switch and timer. Your model will have two screws that must be removed, they maybe in back of the end caps. To remove the lid switch unclip the clips on the right and left side, unplug the harness and tip the cabinet foward. You will see how the lid switch mounts to the cab. Catriver..post back
4/30/2017 10:11:10 PM • Roper RAS6233KQ... • Answered on Apr 30, 2017
3answers
The water pump started leaking and I just want to replace it. I can't figure out how to remove it.
I hope this information may help.
copy n paste
http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=img_FOU23FEA&RefineSearch=0&imgMfg=Whirlpool&Page=4
1) Unplugged electrical cord
2) Removed hot/cold water hoses
3) Took drain hose from laundry room recepatcle
4) Moved washing machine to area where I could lay it down on its back (very important for easy fix)
5) Found (easy accessible in my case) water pump with an inlet and outlet water hose held on with spring clamps.
6) Removed each of the two clamps with pliers and each hose by twisting loose
7) Remove two metal clips holding pump to motor housing
8) Slide pump off shaft - removal is finished!
9) Reversed process for installation, making sure to gently align pump housing when the pump is aligned with the shaft
[probably took less than 15 minutes
"Was this helpful?" YOUR RATEING is very important.thank you
7/22/2015 6:41:59 AM • Roper RAS6233KQ... • Answered on Jul 22, 2015
Roper top loader direct drive washing machine vibration on spin
the counter weights inside gone bad or u need to balance the machine legs , use a leveler to check balance
3/9/2015 6:56:42 PM • Roper RAS6233KQ... • Answered on Mar 09, 2015
2answers
Leaks when the washergoes into the spin cycle.
Could be crack on underhose or possible drum fault
8/12/2014 3:49:31 PM • Roper RAS6233KQ... • Answered on Aug 12, 2014
Only cycle that works is the spin cycle
Defective timer seem far more likely.
5/13/2014 3:35:51 AM • Roper RAS6233KQ... • Answered on May 13, 2014
My washing machine won't stop-
sounds like you blown the timer replacement?
5/13/2014 1:50:49 AM • Roper RAS6233KQ... • Answered on May 13, 2014
RTW4640YQ0 made horrible loud noise banging so I
There are several springs in the machine and it sounds like one of them that you cannot see has broken. To get an idea about the problem, drain the machine and unhook it, lay it down so that you can see what is going on from the bottom of it.
11/4/2013 10:09:40 PM • Roper RAS6233KQ... • Answered on Nov 04, 2013
301 questions posted
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Roper Washing Machines
Most Popular Question
rtw4640yq0 made horrible loud noise
  • Washing Machines
