20 Most Recent
Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer Questions & Answers
Kenmore front loader washer powers on but lets no water in
If the door lock is engaging, then there could be a few things causing the problem. These things are as follows:1) The water valve is bad - you can check this by seeing if when you turn the machine on if power, 115vac is being applied to it. If so the valve is bad, if not read forward.2) There is a part called the pressure switch, it controls the amount of water that flows into the machine. Its connected to the drum by a 1/4" tubing. You'll need to check to make sure that nothing is obstructing the tube.3) Take the bottom of the machine off, called the kick plate. Inside there is a tech sheet with diagnostic walk through's that will carry you the rest of the way If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
Wash Cycle will not start; add garment and door locked lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
